1 members (1 invisible),
46
Mod | | | Forums66 Topics128,043 Posts1,055,610 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 126 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 126 | I have a 1938 2 wheel drive. Two general questions for the group:
1. Is there an easy way to tell whether it is a half or 3/4 ton?
2. What is the bolt pattern for the wheels on this truck?
Thanks!
| | | | | Joined: Nov 2012 Posts: 126 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 126 | | | | | | Joined: Feb 2000 Posts: 5,199 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,199 | Here is the full 1938 specifications, http://chevy.oldcarmanualproject.com/chevyresto/38index.htmI always thought the 3/4 ton trucks had a longer bed and wheel base. If the bed has three stake sides per side, then it should be a 3/4 ton. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Joe, it says right there on the first page of your link. The half ton has a 112" wheelbase and the 3/4 ton has a 122-1/4" wheelbase, same as the one ton.
| | | | | Joined: Aug 2005 Posts: 277 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 277 | Both 1/2 ton and 3/4 ton will have 6 lug nut wheels and two stake pockets in the bed. I believe you should find 3/4 ton bed a bit over 7' long. 1/2 ton rear axle over rear springs. 3/4 ton under rear springs, same as my 39. | | | | | Joined: Feb 2000 Posts: 5,199 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,199 | I didn't want to for sure they had longer beds, because someone would come along prove me wrong.
I almost extended my 1/2 ton frame out to put a long bed on it for a better ride, wish now I would have done it.
Joe | | |
