5 members (TUTS 59, Gdads51, massey1951, JW51, sron48), 92 guests, and 2 robots.
Topics128,038
Posts1,055,583
#1116972 08/02/2015 2:52 PM
I have a 1938 2 wheel drive. Two general questions for the group:
1. Is there an easy way to tell whether it is a half or 3/4 ton?
2. What is the bolt pattern for the wheels on this truck?
Thanks!
Oregon Tarheel #1116974 08/02/2015 3:02 PM
Here is 1938 wheel/tire information.
I did not see number of wheel nuts (but, I'll keep looking).
Other identification information is in that Specifications Manual.
Can you find serial numbers? Here are locations/codes.
tclederman #1117021 08/02/2015 9:27 PM
Thanks, Tim
Oregon Tarheel #1117025 08/02/2015 9:52 PM
Here is the full 1938 specifications,
http://chevy.oldcarmanualproject.com/chevyresto/38index.htm
I always thought the 3/4 ton trucks had a longer bed and wheel base. If the bed has three stake sides per side, then it should be a 3/4 ton.
Oregon Tarheel #1117028 08/02/2015 10:07 PM
Ex Hall Monitor
Ex Hall Monitor
Joe, it says right there on the first page of your link. The half ton has a 112" wheelbase and the 3/4 ton has a 122-1/4" wheelbase, same as the one ton.
Oregon Tarheel #1117218 08/03/2015 8:50 PM
D Online: Content
Both 1/2 ton and 3/4 ton will have 6 lug nut wheels and two stake pockets in the bed. I believe you should find 3/4 ton bed a bit over 7' long. 1/2 ton rear axle over rear springs. 3/4 ton under rear springs, same as my 39.
Oregon Tarheel #1117257 08/04/2015 12:25 AM
I didn't want to for sure they had longer beds, because someone would come along prove me wrong.
I almost extended my 1/2 ton frame out to put a long bed on it for a better ride, wish now I would have done it.
Joe
