1 members (MikeE),
121
Mod | | | Forums66 Topics128,129 Posts1,056,360 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 481 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 481 | I have a 235 engine that has been rebuilt, but never installed. I am in the process of cleaning the paint off the engine that the machine shop applied and painting it like I want, close to original colors. Anyway, I wanted to know what type (brand) and weight of oil I should use and for how long. it will be a little while before I get the engine on the chassis, but I will have the motor on a stand where I can crank it periodically and allow it to run for short periods. Anyone every done it this way?
Thanks in advance,
John | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | There is a nice proper break-in procedure here John: http://devestechnet.com/Home/Project1959235#breakinI hear that Brad Penn 30w Break-In oil is also a good choice. Once you have it properly broke in, put your choice of regular engine oil in. | | | | | Joined: Feb 2000 Posts: 5,221 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,221 | Read Deve's write up, it answers all your questions. It's easier to link it then to keep writing it up all the time.
I can tell you this, don't turn it over till you are ready to break-it in. You need to have the time to do a proper break-in, once thats done, you can start it when you want and for as long as you want. The short little runs are not good for a new cam. Also, just turning it over by hand is not good for it either. It needs oil pressure ASAP, or you risk bearing failure and or cam failure. Best to just let it set.
Oil choice is yours. Name brand 10w30 with additive, or break-in oil from Comp Cams, Royal Purple, or my favorite Brad Penn. All are good choices. Lucas makes a good additive and Comp Cams also makes one, both available at most parts stores. Summit Racing can get you any brand you want. Not synthetic till after 100 + road miles if you want to go that route. | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | Repeatedly starting the engine is the worst possible thing you can do to it. | | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | If you don't mind- explain why "repeatedly starting the engine is the worst possible thing you can do to it", panic.
Thanks, Brad Wrench Fetcher, PhD | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | you need a steady flow of oil to the cam that can only be obtained by running the engine at 2000-2500 rpm gpt 25-30 minutes, or you will wipe out the cam. read the break in procedures of any cam manufacturer online. They give a step by step procedure
| | | | | Joined: Feb 2000 Posts: 5,221 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,221 | Once you break it in, you can run as you want. The only way a cam gets oil on the lobes is from the crank and rods throwing oil off up on the camshaft. The cam bearings do nothing for the lobes, and run off from the lifters is not enough for a new camshaft. Lifter to lobe contact needs as much oil as you can throw at it while they are lapping or seating together, once they mate up, normal operation can happen.
If this engine has an old cam and lifters, then do as you want.
On a side note, once the engine first fires, do not shut it down till the full 20 minutes are done, and have the rpm up to 1500 to 1700 as soon as it fires, do not hesitate and do not monkey with tune up settings.
Joe | | | | | Joined: Jun 2005 Posts: 481 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 481 | Deve,
Great "Initial Run-up/Break-in" movie. Easy on the eyes and very informative.
New question for you. Can you please tell me the two colors of paint' orange (top cover) and aqua/turquoise blue (filter canister) that Chevrolet used for the oil filter holder attached to the manifold of the 1958 Apache?
Thanks for all your help and guidance.
John | | | | | Joined: Jun 2005 Posts: 481 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 481 | Gentlemen,
This is exactly the type information I was hoping for. I'm not there yet, but hope to be there to do the initial run in my stand by the end of the year.
John | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | John the go-to guys on filter colors are Dads50 and tclederman. They know their stuff and can point you in the right direction. | | | | | Joined: Jun 2005 Posts: 481 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 481 | | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | you need a steady flow of oil to the cam that can only be obtained by running the engine at 2000-2500 rpm gpt 25-30 minutes, or you will wipe out the cam. read the break in procedures of any cam manufacturer online. They give a step by step procedure Maybe with hi-hp dual valve spring whumpa-whumpa motors... but stock/mildly warmed up.. no. Wiping a cam is just not a risk that most people need to worry about.. unless something is assembled wrong. | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | whatever, that is the procedure. Given by every cam manufacturer out there. You may not ruin the cam completely, but it sure won't do it any good.
| | | | | Joined: Mar 2010 Posts: 10,281 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,281 | pfarber, Everyone is entitled to their own opinion, but unless you have built thousands of inline-six engines without properly breaking in the cam by insuring adequate lubrication at the lifters, you would better serve the driving public by keeping your opinion to yourself on this issue. Every cam manufacturer, and engine builder recommends the 2,000 RPM for 20 minutes break-in procedure. Why? To prevent returns from irate customers whose cams are wiped from improper cam break-in procedure, I'll bet. Carl
| | | | | Joined: Feb 2000 Posts: 5,221 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,221 | The difference between a good break-in and just a start up is about 20 to 30 minutes and an extra $15 to $25 dollars. Its up the end user to decide if he or she wants to spend the extra time and money.
Joe | | |
