2 members (J Lucas, pauld),
123
Mod | | | Forums66 Topics128,183 Posts1,057,263 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,845 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,845 | I need to haul both sand and flagstone rock in my truck but not too sure as to how much weight these old rigs can safely haul?
Up to 1000 pounds? or until the rubber load bumper attached to the rear frame rails are within a couple inches of the rear axle housing? or.......
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | What size tires do you have on the rear?
You might need to make a few trips | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I'm running 235/75/15 on my 50. P tires 15x6 OEM Stockton wheels One slight issue I have, is on a few occasions I have loaded the bed With Sod , or Yard waist, Landscape Blocks . With the bed loaded I have a very slight rubbing ...pic... ...pic...I had an issue with the bed rubbing, but that might be my wheel tire combo | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | 1950 3104 - 1,500 payload 1953 GM specification manualmore readable in the 1952 GM specification manualI think I'd drive slowly and carefully with that weight; although, I have carried over 1,500 lbs human-weight in my Suburban. | | | | | Joined: Mar 2005 Posts: 209 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 209 | I have the same size tires on my 51. Mine are LT's and I've had 1200 lbs on with no problem. I wonder if yours are passenger tires and underinflated for their max load, causing the sidewall to bulge. Also, unless you scaled those loads, theres no way to know how much was on there. The payload is your GVW minus the empty weight of the truck. My 3104 weighs about 3700 with me, the spare and a few tools. I think GM weighed a truck with a 3 speed, no fluids, spare, jack or any flies on it to come up with 1500 lbs. My 2 cents worth, I love my truck and Chevy in general. After having Fords for years, when I bought my first Chevy a glowing light came from above and I'd been saved! John | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | When I picked up the flooring, the receipt said 2200 lbs, plus me, my wife and little kid, but we are all skinny, so maybe another 300 pounds It didn't really seem to bother it too much. When I drove it from san diego to montana, I had it weighed at a weigh station, 5100 lbs with an empty gas tank and the wife wasn't in it. The fella said "darn, your loaded"
| | | | | Joined: Jan 2015 Posts: 32 New Guy | | New Guy Joined: Jan 2015 Posts: 32 | ...I had it weighed at a weigh station, 5100 lbs with an empty gas tank and the wife wasn't in it. The fella said "darn, your loaded" Curious question: where did your screen name come from...?
Thanks, David
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | I found this website in my first attempts at finding a head for my truck that wasn't broken. The reason I put so much in it is because I had gotten the flooring home before I noticed the weight on the receipt. And the 5100 GVW was just a matter of necessity, I was moving all my belongings, and I just put stuff in, until it was full. Didn't have a lot of choice, I wasn't coming back.
