| | | Forums66 Topics128,095 Posts1,056,480 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 62 | I have 1985 step van with 450000 miles on it with a 292 engine. The exhaust manifold is warped .022 of a inch . A shop would mill it for 100 dollars. This manifold and truck has had its better days. If I doubled the gaskets cold that work. Or is there some other Micky mouse remedy? Thanks | | | | | Joined: Feb 2004 Posts: 29,831 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,831 | Find another shop. All it really needs is a quick trip across a big belt sander, and a lot of older automotive machine shops have such equipment. For a quick and dirty fix, leave the intake and exhaust bolted together and sand them both at the same time. If you've got a pretty good sized woodworking belt sander and a long straightedge like a 4 foot carpenter's level, it's a do it yourself project. Use a coarse sanding belt like a 40 or 60 grit, and take your time, checking often with the straightedge. Jerry
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | If you don't have that capability, I agree, go to another shop. I just got done paying $46 for mine. That was well worth it to know they surfaced them properly and I didn't have to worry about exhaust or intake leaks. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The exhaust manifolds on those 292 in those trucks run so hot they get all out of shape. Grinding or milling wont fix them. Get a new one or a used one from a light duty truck. The 250 manifolds are near the same & retain their shape much better. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2010 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 62 | Will the 250 manifold fit my 292 engine? I might try the belt sander tick. I might look for used manifold. Thanks
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If yours is a cast iron manifold with a 2" opening pointing reward the 250 manifold will fit. Some of the early 250s had 2 bolt exhaust pipe flange. Around the early 70.s they changed to a 3 bolt flange & still retained the 2" outlet. You can use the 2 bolt if you change the flange on the pipe but the 3 bolt is better. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
