1 members (Samantha),
45
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2015 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2015 Posts: 59 | Anybody know where you can get the front engine mount for a 261 in a 1962 gmc pick up,it is a single piece rectangular shaped mount. All the mounts I can locate are the side mount style.
1962 GMC 920 step side 261 4 spd
| | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | I don't believe a gmc came with a 261 engine, that was a chevy engine out of a larger (1 1/2) tn truck/bus.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Dec 2013 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2013 Posts: 54 | I can't offer any advise on the 261 mount. But this may help you out, I have a 283 sbc in my 1950 3600 and I used the horse shoe mount from a '60-'61 v-8 chevy truck. The holes in the horse shoe mount match (visually) to the mounting system from earlier 6cyl AD truck front mounting system.
I just used the cover, plate, rubber biscuit and housing from an AD truck.
Tim | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Go to one of the venders sites and look at a mount from a 1952 chevy and see if that's the one You're looking for could be that when someone installed that engine they used a early mount.
Pete | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I don't believe a gmc came with a 261 engine, that was a chevy engine out of a larger (1 1/2) tn truck/bus. NOTE: GMC kid 7530 - Vancouver BC Canadian GMC's used "Chevrolet" engines (216, 235, 261, for examples) in some/smaller trucks. | | | | | Joined: Jun 2015 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2015 Posts: 59 | This truck is a Canadian gmc , this is the original engine numbers match The ID plate. I will check out the earlier 235 center mount,thanks
