1 members (2-Ton), 133 guests, and 1 robot.
Topics128,114
Posts1,056,287
Members48,439
My 51 3100 has a '50 code torque tube that has no dowel in the front bushing, making it a "late" '50, right according to the searched threads by jorb, etc.
So which Okie is right, a 50 or a 51? The vendors make the break at the model year without the early or late designation....so are there other differences than the dowelling, like the OD for example?
I'd like to confirm by objective evidence, like measuring, rather than trial and error.
NHluvstruck...
1951 3100 5-window,.sold, regretted
https://stonefacegarage.wixsite.com/mysite
51 Chevy Restoration Page
In the parts book, there are some of the dimensions for the original bushings. You might get some clues from that.
1951 1 Ton Completed
Thanks for the lead on that, I did some checking and got this:
The front bushing for the 41-50 is 1" long, the 51-54 is 1 3/16" long.
Easy to check- I slid a bent wire in by the shaft and caught the back edge of the bushing, then marked the depth and measured it - got the 1 3/16" bushing!
This means my '50 code torque tube has the '51+ bushing, so it's a late '50 year change to watch out for.
For what it's worth, the "Ask Jim" responder advised to use the incorrect '50 replacement based on the code only , even though there was no dowel pins. I plan on advising them of this when I order the '51 bushing
NHluvstruck...
1 Offline
I tore down a 1951 torque tube and a 1949 torque tube and they were both 1" long.
The 1949 had a dowel and the 1950 did not have a dowel, but the dowel was tough to find.
I think I remember the rear bushing being longer but I dont remember the length. Are you sure you are comparing front bushings on both?
1 Offline
http://chevy.oldcarmanualproject.com/parts/1929_54/346.htm
It looks like the front bushing on both are 1" long
see under "BUSHING, Propeller Shaft Housing (torque tube)"
4.451
Are you certain you do not have dowels?
Page 483 of the 1957 revision
http://chevy.oldcarmanualproject.com/1929_57chevyparts/57cmpc0483.htm
Pretty clear there, front bushing is 1 3/16".
And no dowels.
This is a press fit bushing, only the slip fit must be dowelled.
My guess is you could use either but I'd have to drill a hole for the dowel.
Buyer beware of the different editions of the parts manual!
NHluvstruck...
