2 members (lumbersawyer, klhansen), 75 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#1116172 07/29/2015 2:01 AM
I have a '52, 3100 with the original 216, Rochester B, 6V, oil-bath, etc., pretty much how she came from the factory. I have owned her for two years. Previous owner rebuilt the engine. I had her tuned, plugs, timing, points, wires done by an old-timer when I first got her. She runs great. The problem is that she will sit for two or three weeks sometimes without being cranked. Then, I have to crank and crank and crank and crank, then crank some more before she finally fires. I can crank her the next day, or several days later with no problem. So, I am absolutely sure that the problem is that the carb empties when she sits for so long. There is absolutely no evidence of gas leakage anywhere under the carb. I have rebuilt the carb (not for this reason, but for sticking float)and the fuel pump(original glass bowl) has all new gaskets. I know that the fuel bowl is vented to atmosphere, so could fuel simply be evaporating during the time she is not ran?
'52 Chevy 1/2 ton running original gear
Not sure if its relative to your problem but I have a 350 and 305 V8's in my garage and if they sit for a "spell" I have to pump and pump and pump to get gas to the carb. I'm running regular fuel pumps and 4-barrels. Seems to just dry up but like you, once started I can go back in a day or two and they'll fire the first round. Let them sit for a month and its pump pump.....I can pull the choke out and it does help though. Doe pulling the choke help you??
yep that is what is happening, I have to fill the float bowl every weekend, but if I drive it in the middle of the week, it works fine. It isn't really that big of a deal. It is normal
V
V Offline
I have a similar problem on another project car I have. It runs great but if it sits for a couple weeks the fuel evaporates out the float bowl vent and likes been said I have to turn it over & over quite a bit to get the bowl filled. It'll start right up and run great then.
An electric fuel pump would cure it but I can live with it.
Good luck
Dave
Thanks for all the replies. I figured that was normal, but wanted to check with others.
I have the same problem with my truck. My solution is to use starting fluid so I don't have to wear out the starter and battery.
daveboy #1117996 08/08/2015 11:34 AM
There are mechanical fuel pumps with primer arms that you can pump to refill the fuel bowl on the carb.
My 42 Ford has one and yeah, if it sits a week then I pop the hood (check the oil, pump the primer) and it will start right up.
daveboy #1118363 08/10/2015 11:11 PM
I have the same problem with my 235. I found if I give her some choke and pump the gas a couple times she'll usually fire right up. Then I started thing. Thats the way I was taught when I started driving! I wonder if electric fuel pumps and TBI hasn't spoiled us. Also, I wonder if what passes for gasoline now evaporates faster. John
Q
Q Offline
Put in a new fuel pump.
