6 members (cmayna, Gdads51, Ridgeback, TrknGMC, TUTS 59, 1 invisible), 140 guests, and 0 robots.
Topics128,130
Posts1,056,370
Members48,441
#1114549 07/19/2015 2:21 PM
Is there any magic way to keep the knurled nut/collar from backing off? Also is there another material available for the seal other than cork? I cannot get this to stop leaking, I tighten up the collar, and after a 20 minute drive it is loose and leaking again. Thanks for any suggestions.
Some threads on the topic:
Thread 1
Thread 2
Thread 3
This item has been mentioned in previous posts as a seal. I have not used it but it might be worth looking in to.
http://www.oreillyauto.com/site/c/d...h_N0243_-1_-1&pt=N0243&ppt=C0142
Ed
Thanks, Ed
If anyone uses that seal, please report back on how well it works. Inquiring minds (with leaky seals, or who want to avoid leaky seals) want to know.
I have used the O-ring on many 1929-32's. They do not have an adjustable collar/nut, the seal is just crimped in place. It has worked well on those.
My Blog
thanks for the responses...
"Thread 1" above was mine. Loctite worked.
1953 Chevrolet 3104 1/2-Ton
More pix
Thank you. I have this problem since changing out my rear gears.
Dennis
Below is a pic of a
1954 Chevrolet 3100 Hydra-Matic Ball Housing with Fresh Seals
If you look closely at the rear of the torque tube retainer threaded on ring.
The ball housing has about a inch of extra threads behind the torque tube retainer.
Why couldn't you screw on a large thin nut first to use as a locking nut to hold the torque tube retainer.
That's if you have a extra threads on the ball housing.
Post your question over on the VCCA Chat site. Skip Gear (AKA Junk Yard Dog) Posted in the past about replacing the cork seal with an O-Ring which stopped most leaks from the Torque tube Bell fitting.
"If it ain't Steel it ain't Real"
"Earth the insane aslyum for the rest of the Universe"
41 1/2-ton, a work in progress
68 Shortbed stepside 327/325hp/700R4
Found the article that I told you about on the torque Tube ball Seal. Will send it to you via email
