3 members (MickeyP, Gdads51, TUTS 59), 30 guests, and 6 robots.
Topics128,013
Posts1,055,312
Members48,419
#1115755 07/26/2015 11:33 AM
So I am looking at a few different engines to put into my 1949 1-ton. I have it narrowed down to a 292 or a 350. I know either way I will have to do some modifications (engine cradle for sure on both). I have the cradle ready to go in just waiting on my decision on the engine. My first question is how will I know where to bolt up the cradle on the frame and secondly at what angle should the engine set? Lastly if I went with the 292 and used a early 70's SM465 4-speed transmission will the stock transmission crossmember still be used or will I need a aftermarket transmission cradle?
1949-52 Chevy 3800 1-Ton Flatbed
More pix on Photobucket
Blind1968 #1115767 07/26/2015 2:05 PM
Cradle placement will depend on several items that you choose. Angle is best to set to match pinion angles on rear differential or as close as possible. If the rear is 4deg up then engine usually is 4 down. (straight line setting).
After considering pinion angle, level heads are next desired.
forward/rear placement is space available. Basically clearance for 350s distributor and in the front fan blades and room for fan shroud. You can not do much to adjust rear clearance on the 350 but you can do mod on the front to gain space.
Side to side centered is first choice but some left or right shift to clear obstacles (I E steering). Choice of exhaust will also help here with early chevy rams horn exhaust being the tightest.
Baking in the nice desert sun, breathing life back into a 48 3800 5 window.
Blind1968 #1115773 07/26/2015 2:49 PM
You definitely don't want your transmission output and the pinion to be in a perfectly straight line. I believe there is a Tech Tip on this.
1951 1 Ton Completed
Blind1968 #1115785 07/26/2015 4:23 PM
Riding in the Passing Lane
The 292 would be easier as you will not have clearance problems with the steering gear. It will look more natural. The V-8 will run better.
1972 Chevy c10 Cheyenne Super
Blind1968 #1115796 07/26/2015 6:03 PM
I didn't think a 292 was an easy swap/ replacement for 235. What is required to make it work?
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
Blind1968 #1115854 07/26/2015 10:19 PM
It's not a bolt in swap but it is easier then the 350 V-8.
