7 members (BC59, David Bush, MikeE, Bucker, MickeyP, Rexville48, dt235sd),
83
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,702 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 240 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 240 | Hello All,
I am re-installing my clutch - moving "old" FW and clutch to "new" engine. However, I did not mark the pressure plate and FW for orientation before I disassembled them.
When re-installing, I could not find an "X" on the pressure plate, though the FW is marked with an "X". The pressure plate was stamped "rebuilt", so it is not the original.
I've checked other threads, and my situation, not having a clearly marked "X" on the pressure plate, seems to be typical.
My question is, does a rebuilt pressure plate require orientation to the "X" on the FW? If it does, what feature should I align with in the absence of a clear "X" on the pressure plate?
Thanks in advance for the help.
Best regards,
1947 3100 Advanced Design
Never, never, never, never give up. - Churchill | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I have never installed a pressure plate in any particular place. I don't see where it would make a difference. | | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | no,just line up the bolt holes and put the bolts in | | | | | Joined: Nov 2010 Posts: 430 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 430 | I can understand why you are asking the question. You want to make sure that the pressure plate is balance with the flywheel...
If your pressure plate and flywheel were balance I would certainly hope that they were done independently from one another. It would be very rotten of someone to do them together.
I would reinstall and not give it a second thought. | | | | | Joined: May 2015 Posts: 236 Shop Shark | | Shop Shark Joined: May 2015 Posts: 236 | A pressure plate and clutch disk are not part of the engine and as a result would be zero/neutral balanced by the manufacture. When removing a used unit and reinstalling it is marked to simply allow for wear matching.
The flywheel on the other hand can relate to the engine. If the engine is internal balanced the flywheel should be neutral balanced. If the engine is external balanced then builders will balance the flywheel to the engine.
If you are building to performance engine levels then every thing is balanced as a unit for high RPM performance.
Baking in the nice desert sun, breathing life back into a 48 3800 5 window. | | | | | Joined: Mar 2012 Posts: 240 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 240 | Thanks All.
I appreciate your comments and the assurance that I'm not missing something.
Best regards,
Never, never, never, never give up. - Churchill | | | | | Joined: Jul 2015 Posts: 3 New Guy | | New Guy Joined: Jul 2015 Posts: 3 | I have a related problem. I got my 292 rebuilt and cannot get the flywheel to bolt up to the pressure plate for the life of me (the tranny and engine are currently in the truck, so it's tough to see any alignment markings). The flywheel and pressure plate haven't changed. I can get one bolt to catch but none of the adjacent ones will. Spinning the pressure plate to another hole doesn't help. Any tips or tricks that I might be missing? Of course I didn't mark the alignment when I removed the engine like I should have! | | | | | Joined: May 2015 Posts: 236 Shop Shark | | Shop Shark Joined: May 2015 Posts: 236 | You are using a clutch disk alignment tool? Checked for a side on disk marked flywheel side?
Baking in the nice desert sun, breathing life back into a 48 3800 5 window. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | When you say the tranny is in the truck, do you mean it is installed? The pressure plate should be installed before you put the transmission on. When bolting up the pressure plate, start the first bolt but don't turn it to where it is applying pressure. You need to install all six before any of them are applying pressure. | | | | | Joined: Jul 2015 Posts: 3 New Guy | | New Guy Joined: Jul 2015 Posts: 3 | Just to make sure I'm explaining everything correctly (novice mechanic here), I essentially pulled the engine and left the tranny (SM 420) in place. I don't think I bolted the ones that threaded correctly with much pressure, but maybe I put too much pressure on (?). | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | What I was questioning about was it seemed that you had the transmission in place but the pressure plate was not bolted down. That is the wrong order to do things. The pressure plate should be bolted up tight before installing the transmission. | | | | | Joined: May 2015 Posts: 236 Shop Shark | | Shop Shark Joined: May 2015 Posts: 236 | If your sure all parts are correct and in correct alignment then you may have to do what I did some 20 years ago. Get two bolts about a 1/4 in longer then the stock bolts. put one in one hole and on opposite side the other. Turn them in just enough to get the plate lined up and started down until your stock bolts threads grip. Then put in the stock bolts and once all but the two are in remove the two longer bolts and replace with stock.
DO NOT LEAVE in longer bolts. MAKE SURE all is correctly aligned.
Baking in the nice desert sun, breathing life back into a 48 3800 5 window. | | | | | Joined: Jul 2015 Posts: 3 New Guy | | New Guy Joined: Jul 2015 Posts: 3 | It took some creativity, but the flywheel is bolted up now. Thanks for the help folks! | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | How did you get it to work?
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | |
