| | | Forums66 Topics128,059 Posts1,055,820 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 39 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2012 Posts: 39 | I got a great deal on a posi 9" and just got finished cutting and grinding all of the perches and brackets off. As I was looking for new leaf perches I am only finding the modern 2.5" wide variation and not the 1 3/4".
Are there any easy donor leaf packs that bolt in or would require little work? If so, what should I snag while at the junkyard pulling the leaf pack.
Anyone with some Ford 9" experience and possibly some photos to share?
Thanks!
1955.1 Chevy 5 window 3100 Instagram - @1955.1chevy
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | A visit to a place that makes trailers will probably give you what you need. If not buy a piece of 1 3/4" rectangular tubing and make your own. Your 9" has either 3" axle tubes (car) or 3 1/4" (truck ). A 1 3/4 x 4 will let you trim out stock height saddles or you can raise/lower the rear with taller saddles---up to 1.75 x 8. If saddles are on top taller ones raise and visa versa for the bottom.
Evan
| | | | | Joined: Feb 2007 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 46 | I got mine from summit racing. They are a 3 inch drop. I think jegs might carry them as well. I believe they are a westin chassis brand. | | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | JC whitney has them for about 12.00.... 1 3/4 perches I bought a pair for my 46 1/2 ton and welded them to a S-10 rear and used my original springs
