2 members (78buckshot, NJC),
99
Mod | | | Forums66 Topics128,149 Posts1,056,819 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2002 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2002 Posts: 48 | I just bought some seat belts with retracting shoulder harneseses from chevyduty anybody have any advice on installation? Or can you direct me to some install pics? The instructions are very generalized. Thanks Zach
If you need a tool and don't buy it, you will find you have paid for it and don't have it.
| | | | | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | I recently installed a pair of retracting harnesses in my panel. The only way I found to mount them is to drill a hole in the inner wall (where you want the mount points) then cut an "L" in the sheetmetal about 3" from that hole, and peel the sheetmetal back. That allowed me to put a reinforcing plate inside the wall, bolt the seatbelt assembly through that plate, and then tap the "L" back flush with the wall and patch it with fiberglass (I'll be upholstering over the patch later). I did this for all four mounting points in the cab (top and bottom each side).
The kit I ordered (not ChevyDuty) came with a latch on a rigid plastic extension, which worked out very well with my bucket seats (from a '96 burb). I drilled a hole in the back of the seat pedestal (which took forever, very hard thick steel) and offset the latch assembly with a right-angle steel bracket. This offset was necessary to set the latch in the inside corner of each seat and maintain correct tension points. You want these to be a safety item rather than a potential hazard, so pay attention to where the belts cut across your body, and adjust the mounting points accordingly.
I should point out that the only reason I chose a retracting harness is because I have a panel, and need the belts to tuck up next to the wall when I'm crawling into the back. Lap belts can be bolted directly to the seat mounts and won't require any cab cutting; retractors must be bolted to the wall vertically to work correctly.
Hope this helps. Good luck. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | My plan on mine is to drill holes the right size, drop a string down through the holes and fish some plates back through, and drill holes and plug weld the reinforcing plate in place. If you have a 5 window cab this may be a problem.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Nov 2002 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2002 Posts: 48 | Thanks for the info guys, I also found a good tech article at chevytrucks,org in the technical section on seat belts with retractors in a AD truck.
