5 members (dt235sd, Toadwart, Chip O, 2 invisible), 106 guests, and 1 robot.
Topics128,087
Posts1,055,998
Members48,430
#1114858 07/21/2015 2:40 AM
TexWis 49
TexWis 49
Quick question....
I am going through restoring my 49 3100 and when I hooked up my turn signal assembly and grounded it out to the steering column it starts to constantly flash. Blinkers work but when I turn the blinkers off to the center position it just keeps flashing. Before I took things apart it was working fine.....
Any help on what I should check would be appreciated.
Adam
Chopped 1949 Chevy 3100, first-time bolter
Adam, what flashers are on? One side or both sides? Front/rear
~ Jim Schmidt, Bucks County, PA
1953 Chevrolet 3804 1-ton
In the DITY Gallery
your flasher may not be wired correctly
the pilot light on you signal switch should go to the P post on the flasher.
or a bad flasher
TexWis 49
TexWis 49
I will have to check the lights to see which ones are flashing... right now I have all the fenders off and the bed, so lights are all disconnected. It appears that it is the hazards (so all; both sides, front and rear) are flashing.
The weird thing is that before I took everything apart the blinkers, hazards and turn signal switch worked fine. I didn't mess with anything (that I know of) so I am puzzled as to why all of a sudden it is acting up.
Thank you!
Adam
Didn't mess with anything? You have all the lights and the grounds to them disconnected and you expect them to work?
TexWis 49
TexWis 49
Good point... I will take that advice and wait until I have everything put back together....
Thanks Cletis!
Adam
