1 members (Hotrod Lincoln), 327 guests, and 3 robots.
Topics128,169
Posts1,057,102
Members48,463
#111502 06/26/2002 7:30 PM
Does anyone know if a 1954 GMC Panel can use rear fenders from an earlier Chevy Panel?
1954 GMC De Luxe COE
#111503 06/27/2002 1:23 AM
!No problema! Good luck with the captive nuts. grin
#111504 06/27/2002 1:24 AM
Yes - Panel/Suburban fenders were the same through the whole run as far as I know. Better get MT to verify this though cause he's the panel fenderman - the walrus - koo koo kaachoo.
#111505 06/27/2002 4:14 AM
Junior Member
Junior Member
Is far as I know all panel/ suburbans had the same "corners" Which are you looking for? I need the driver side.
I cannot find how to send Metalman an email, so if he reads, drop a line plz.
#111506 06/27/2002 5:19 PM
Thanks for the replys.
Splashoil, what did you say about captive nuts? There is so much crud on the underside of my fenders that I haven't had a chance to study how they connect to the rest of the body.
#111507 06/28/2002 10:54 PM
Anonymous
Unregistered
Anonymous
Unregistered
I am still around. New email address [email protected]
#111508 06/28/2002 11:27 PM
Those captive nuts are for the bolts attaching the fenders. Be patient, slosh 'em a few times with some type of oil. I had a hell of a time with mine, some came off with the sheet metal from the body--more patch/repair. You might try some carefully applied heat, then slosh 'em while they are warm. You don't need exotic spray penetrants for this, heavier oil is probably better, higher flash to fire point and all.... :p
#111509 07/02/2002 4:51 AM
Anonymous
Unregistered
Anonymous
Unregistered
OldkarKook !! See how they fly like lucy in the sky............ Those panel fenders were all the same from '47- 55 1st series 1/2 ton to 1 ton GMC & Chev.
Suprisingly enough the stainless trim on these fenders was only avaliable in the panel van & not in the suburban models.
#111510 07/02/2002 12:28 PM
all panel truck rear fenders are the same. and.....speaking of deluxe trim strips,i have a complete set (all 14 pcs.) for sale.
