10 members (5 Window 9434, cmayna, 78buckshot, Samantha, DJMTruck, dt235sd, Opelika Tom, Gdads51, HandyAndy, 1 invisible),
94
Mod | | | Forums66 Topics128,062 Posts1,055,847 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2013 Posts: 14 TexWis 49 | | TexWis 49 Joined: Aug 2013 Posts: 14 | Quick question....
I am going through restoring my 49 3100 and when I hooked up my turn signal assembly and grounded it out to the steering column it starts to constantly flash. Blinkers work but when I turn the blinkers off to the center position it just keeps flashing. Before I took things apart it was working fine.....
Any help on what I should check would be appreciated.
Adam Chopped 1949 Chevy 3100, first-time bolter
| | | | | Joined: Feb 2013 Posts: 613 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 613 | Adam, what flashers are on? One side or both sides? Front/rear | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | your flasher may not be wired correctly
the pilot light on you signal switch should go to the P post on the flasher.
or a bad flasher
| | | | | Joined: Aug 2013 Posts: 14 TexWis 49 | | TexWis 49 Joined: Aug 2013 Posts: 14 | I will have to check the lights to see which ones are flashing... right now I have all the fenders off and the bed, so lights are all disconnected. It appears that it is the hazards (so all; both sides, front and rear) are flashing.
The weird thing is that before I took everything apart the blinkers, hazards and turn signal switch worked fine. I didn't mess with anything (that I know of) so I am puzzled as to why all of a sudden it is acting up.
Thank you!
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Didn't mess with anything? You have all the lights and the grounds to them disconnected and you expect them to work? | | | | | Joined: Aug 2013 Posts: 14 TexWis 49 | | TexWis 49 Joined: Aug 2013 Posts: 14 | Good point... I will take that advice and wait until I have everything put back together....
Thanks Cletis!
