1 members (‘37ChevyPU),
86
Mod | | | Forums66 Topics128,211 Posts1,057,476 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Thats bad. Have you contacted him so he can make a recommendation? 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | Paul-
I hate that for you, but thanks for posting; and +2 on sstock's recommendation to contact them. They've even helped me out before with things I didn't purchase from them. (until I started better record keeping, I'd get confused with what came from where)
That mat almost looks a little too original. I've been looking into floor mats recently, so keep us posted if you do get any feedback.
Thanks Brad Wrench Fetcher, PhD | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Thanks for the feedback guys. I bought the floor mat probably two years ago so I very much doubt that Jim Carter would do anything about the issue. That company has never been very supportive to me so I have deleted them from my vendor list. I suspect that one company produces the same mat for all of the reproduction companies. My intent is to warn others of this defective product as it is a total waste of money. I am planning on making another mat from 1/4 rubber sheet stock sold by the foot at Tractors Supply. It doesn't have the ridges as per original, but will still help to deaden some road/gear noise.
If only companies sold products that actually worked... | | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | I am planning on making another mat from 1/4 rubber sheet stock sold by the foot at Tractors Supply. It doesn't have the ridges as per original, but will still help to deaden some road/gear noise. Well, we're on the same page with that one... I picked one of the mats up yesterday that came from there. A neighbor had a mat he didn't need; it's 3/4" but I'm still planning on using it.Your vendor mat will be VERY useful for a pattern. I don't have a pattern- I plan on shaping it out in sections, somehow. Brad Wrench Fetcher, PhD | | | | | Joined: Feb 2008 Posts: 1,124 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,124 | I made a pattern for the rubber floor mat material in my '37, using spliced paper grocery bags. It took some trial and error efforts, but got the job done. I added foil insulation to help reduce cabin heat and some of the road noise. | | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | That's the method I'm thinking of- good idea Sparky. Now, I still wish I had the original worn out mat, either way.
Brad Wrench Fetcher, PhD | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | If your engine and transmission are out of the vehicle, you can cut the mat to the outside dimensions and then trace all of the perforations needed from underneath. An enamel paint marking pen works great. | | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | Looks good, Paul.
Just out of curiosity, what did you use to cut the TSC mat?
Thanks Brad Wrench Fetcher, PhD | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Hey Brad,
I used a garden variety utility knife with a new blade. I made all cuts along a steel framing square functioning as a straight edge. Most cuts required a couple of passes with the blade to cut all of the way through the rubber.
Paul | | | | | Joined: Apr 2006 Posts: 273 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 273 | Not tryin to get off-topic, but I heard pond liner makes good floor mats. I never tried it myself because its pretty expensive, but the guy who told me says it works good. The stuff I saw at Home Depot looks kinda thin, and might wear out fast on a truck floor.
Just wonderin.
| | | | | Joined: May 2006 Posts: 934 'Bolter | | 'Bolter Joined: May 2006 Posts: 934 | the crap mat - yish.
I like the mat you made. Better quality and for less. You could make a paper pattern - and sell them. I could / would like to make a mat like yours - but 95.00 for a pattern from JC is out of hand. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I would contact Jim Carter. Always been fair to everyone. He actually has a direct email and will eventually answer. He does not want to sell inferior products. He has no control over a Chinese company changing rubber compounds from time to time which dry out and crack. He gets screwed by that the same as you. It is his job to make it right. Your pictures should convince him you are legit. A kind email explaining the issue is the answer. Not hate mail. He is a valued supporter here. If you reach out and you're sincere and he does not make it right, let us know. We will not consider this a warning about him until you do that. The value of all these vendors, forced to sell Chinese parts, is how they respond to a legit complaint. Keep in mind, rolled up for two years while thermal cycling is a bit long even though it should have lasted.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | I would contact Jim Carter. Always been fair to everyone. He actually has a direct email and will eventually answer. He does not want to sell inferior products. He has no control over a Chinese company changing rubber compounds from time to time which dry out and crack. He gets screwed by that the same as you. It is his job to make it right. Your pictures should convince him you are legit. A kind email explaining the issue is the answer. Not hate mail. He is a valued supporter here. If you reach out and you're sincere and he does not make it right, let us know. We will not consider this a warning about him until you do that. The value of all these vendors, forced to sell Chinese parts, is how they respond to a legit complaint. Keep in mind, rolled up for two years while thermal cycling is a bit long even though it should have lasted. Not looking for your approval, just stating the facts. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I do disapprove of your heading "Buyer beware". You are saying buyer beware of Jim Carter. I disapprove of that. Furthermore, I explained why it may not be the vendors fault. You have not given them a chance to respond because of "deleting them from your vendor list". We have all had some parts problems from every vendor. There are many stories about quality, fit, etc. The proof is how they handle it. You are "warning" us about an issue that you refuse to try and solve. NOT Kosher, NOT "facts". I know for a "fact" that he is honest. FYI: JC has floor matt material made in the U.S.A. Cut to fit. Probably actual natural rubber. There are two types of rubber, natural and synthetic. Then there are products made from recycled water bottles, old tennis shoes and tires.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Jim Carter Website:
Important: NO returns without your invoice!
NO return of special order items!
NO cash returns after 30 days!
Satisfaction Guarantee: 100% Satisfaction Guarantee Our 100% Satisfaction Guarantee is our commitment to rendering outstanding service to you, Our customer. It is hands-down the best guarantee out there. We keep it pretty simple:
We’ll get your orders right. If your order isn’t 100% accurate, then we will refund your freight, issue a call tag for the incorrect merchandise, and cover the shipping costs to re-send you the correct product. We’ll ship your orders when promised. Almost all orders are shipped within 24 hours (next business day). And, if a rush air freight order is in by 1:00 PM EST on a business day, it will ship the same day. *Guaranteed. We’ll respond promptly to your requests or comments and always try to resolve them to your satisfaction. We’ll even follow-up to make sure we’ve met your service expectations.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Almost all (but one) of my experiences with Jim Carter Truck Parts are that he/they are excellent in trying to provide customer satisfaction. I have received refunds for parts that I did not install for more than two years - the parts were wrong, or they were unsatisfactory. In one case, it was a rebuilt part. | | | | | Joined: Dec 2013 Posts: 178 Shop Shark | | Shop Shark Joined: Dec 2013 Posts: 178 | Sorry to hear about your disappointing item. I had heard the term 'paper thin' about these types of mats when I was searching the vendors for my own mat. I decided to cut my own from a used Photobucket222 truck bed mat. I like this particular style mat because it has large raised dimples on the under side to channel out moisture. I used a large cardboard box cut into sections as a template. Then I used a quality pair of poultry shears to cut the thick rubber. $10 bucks and 3 hours labor. Good luck in whatever you do to finish the job. Thanks for the post. Photobucket111
Have you ever noticed that anyone driving slower than you is an idiot and anyone driving faster than you is a maniac? - George Carlin
| | | | | Joined: Jan 2014 Posts: 3,690 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,690 | That looks really good, Marko
1951 3100
| | | | | Joined: Nov 1995 Posts: 5,747 24601 | | 24601 Joined: Nov 1995 Posts: 5,747 | Concur with Bart et al above. Give Jim a chance to make it right -- he's a good guy.
FWIW, I purchased a floor mat from Jim a few years ago and it is just fine and holding up like new.
Good luck!
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | This topic certainly has gotten wings. I have been on this forum for long enough to know that often subject topics meander and become convoluted. This may be a contender for the record books, as inference-observation confusion has reached uncharted levels.
On my second reply I said: “Thanks for the feedback guys. I bought the floor mat probably two years ago so I very much doubt that Jim Carter would do anything about the issue. That company has never been very supportive to me so I have deleted them from my vendor list. I suspect that one company produces the same mat for all of the reproduction companies. My intent is to warn others of this defective product as it is a total waste of money”
I think that clearly states my “positive” dealing with the vendor in the past, and the statement of “Always been fair to everyone” is simply not true. I could give you the gory details of poor performance and lack of accountability, but I felt that was not germane to this topic. I tried with the patience of Job to reach Jim, but he was never “in”, nor did he return repeated phone messages or emails, never got past the service manager. My entire reason for making this thread is to demonstrate that the products did not serve the functions as they were intended, PERIOD. I have more allegiance to the fellow bolters on this site than I do for a vendor selling an inferior product. The mat and stomp starter are junk….the images don’t lie. I don’t want to see others waste their hard earned money. The vendors can sort out their own mess.
John, I realize in your position in this is sort of prickly and I regret the discomfort it may impact onto you, but I hope the 1st amendment is good on Stovebolt?
I am offended by some cyber bully that crams down my throat as to what they perceive reality. Tell you what “bartimos”, I really don’t care what you approve or disapprove. Do you want to buy a great condition floor mat?
How about this? If JC is such a great guy…why not get him to donate the price of that crap floor mat and stomp starter bellows to the Stovebolt in my name? The donation total should also include the price of shipping and handling too, right? Seems pretty reasonable, doesn’t it?
Oh yeah, I am still on the lookout for quality reproduction Chevy parts.
Paul
| | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | Not looking for your approval, just stating the facts. It is not about seeking approval but a reminder on how to do business. We all drop the ball from time to time myself included. Jeffrey | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | This topic certainly has gotten wings. I have been on this forum for long enough to know that often subject topics meander and become convoluted. This may be a contender for the record books, as inference-observation confusion has reached uncharted levels.
Paul I have dealt with various venders and none has been flawless. If it is not quality the part comes damaged, or the part does not fit. I am glad when a fellow poster gives us the heads up and warns us about doing business with a vendor. Your original post left many key details out. Responses can only be made to what is written. Jeffrey
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I bought and toured Jim Carter's business. I think he really tries to get the best pieces to sell us.
But 2 years after you buy something, you are right. It is hard to think or expect a vendor to do anything about it. Jim Carter is the vendor, not the manufacturer. Two years is just a little too long IMHO. I don't think that would be reason for me to drop him from my vendor list or make the buyer beware post about a chunk of rubber. And I am not looking for approval for my post. Good Luck. | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | I bought and toured Jim Carter's business. I think he really tries to get the best pieces to sell us.
But 2 years after you buy something, you are right. It is hard to think or expect a vendor to do anything about it. Jim Carter is the vendor, not the manufacturer. Two years is just a little too long IMHO. I don't think that would be reason for me to drop him from my vendor list or make the buyer beware post about a chunk of rubber. And I am not looking for approval for my post. Good Luck. I think as a customer that a floor mat for my truck/car should not fall apart after 2 years. As a business owner I would want it brought to my attention when a part I sold failed as bad as that rubber mat. 1. Because I then can take steps to see if the manufacturer will make good. 2. Know to stop selling that product. 3. Find a new source. | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | I think as a customer that a floor mat for my truck/car should not fall apart after 2 years.
3. Find a new source. You nailed it, the service life should be well over two years without any question. | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | OK. I can agree that it "should" have a service life of over two years. But does it come with a warrantee for 2 years? If not, I don't know why one should expect that the vendor warrantee anything. He can discontinue the product, but that really doesn't make him "responsible" to pay anyone back or to donate something. Maybe he can work out a replacement with the manufacturer, but that would be up to him if he wanted to take on the task. The squeaky wheel gets the grease, but "Buyer Beware" messages isn't the way to go. I'm sure there is a return policy. They are there for a reason. | | |
