| | | Forums66 Topics128,042 Posts1,055,518 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 2 Junior Member | | Junior Member Joined: Aug 2004 Posts: 2 | Hello folks, great place you have here! I acquired a 1956 3600 in great shape for a 50 year old, and am in process of bringing her back to glory. Not sure what to do about this old undercoating tho... surely there has to be a better way that a chisel and hammer to remove it? I'm leaning toward trying a torch and a putty knife, unless someone has an easier/cleaner way. Thanks much
artificial intelligence will never overcome natural stupidity
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | Why remove it? If it is doing the job, leave it in place. If you do have to remove it for rust repair or personal pref I would suggest a torch with a low flame. It will smoke and stink like heck but afterwards you can scrap or wire wheel the remainder off. Just hope you do not have neighbors close by who are enjoying the outdoors when you fire it up. | | | | | Joined: Jul 2004 Posts: 29 Apprentice | | Apprentice Joined: Jul 2004 Posts: 29 | Good question. I've been using a chisel and hammer. It's not easy.
fifty-one half-ton
| | | | | Joined: Feb 2001 Posts: 164 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 164 | This has come up several times at Len Stuart's site www.autobodystore.com and most guys seem to go with the torch to soften and putty knife to remove procedure. Again, if the U/coat is sound, maybe just leave it? Bruce Palmer [email protected] | | | | | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | Been there done that!!!!! I did find a product by Share Corp. called Safetey Solvent spray on wipe off take's a bunch and smells like the devil. Heating, chesel and hammer, sharp scraper, it is a job. As close as I can figure it is a tar base, but when your done it sure makes it easier to work on those things.
popcorn The Truth is Out There (would I do it again not for a daily driver I wouldn't) | | | | | Joined: Aug 2004 Posts: 2 Junior Member | | Junior Member Joined: Aug 2004 Posts: 2 | As much as i'd love to leave it, the u/c appears to be whats holding the floor corners together in several spots. torch it is, thanks for the help.
| | | | | Joined: Jul 2002 Posts: 188 Member | | Member Joined: Jul 2002 Posts: 188 | Wouldn't a heat gun work better than a torch??? | | | | | Joined: Apr 2004 Posts: 375 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2004 Posts: 375 | I used Easy Off oven cleaner. It worked. | | | | | Joined: Aug 2004 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 196 | just get a bon fire going and set it in there for a 1/2 hour it will remove un wanted paint to | | | | | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | Where's Wookie when ya need advice on fire??? | | | | | Joined: Apr 2004 Posts: 84 Member | | Member Joined: Apr 2004 Posts: 84 | I think I chiseled 50 lbs. of that stuff off of mine. It looked like tar & chip road resurface and made me think the truck once belonged to a paving contractor or a roofing company. Did anyone else have gravel stuck in the goop? The whole underside was coated with this gravel. Still can't get off the fenders. | | | | | Joined: Apr 2004 Posts: 84 Member | | Member Joined: Apr 2004 Posts: 84 | I think I chiseled 50 lbs. of that stuff off of mine. It looked like tar & chip road resurface and made me think the truck once belonged to a paving contractor or a roofing company. Did anyone else have gravel stuck in the goop? The whole underside was coated with this gravel. Still can't get off the fenders. | | | | | Joined: Dec 2003 Posts: 103 Member | | Member Joined: Dec 2003 Posts: 103 | Eastwood sells a product for removing undercoating. Part number 31130Z. Can't vouch for it personally, but I have had good luck with other products I have purchased from them. | | | | | Joined: Apr 2004 Posts: 29 Junior Member | | Junior Member Joined: Apr 2004 Posts: 29 | I removed the undercoat on my fender flaers and bed sides with lots of MEK and a 1-1/2 stiff putty knife/scraper. A little help with a scotchbrite pad in my die grider got the stuff in the corners and hard to reach areas. | | |
