| | | Forums66 Topics128,167 Posts1,057,015 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#11140 05/24/2003 9:23 PM | Joined: Jan 2003 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2003 Posts: 33 | Hi, I was timing my '54 3800 and saw sparks flying on the vacuum advance bracket :confused: What would be the reason that this happens? Thanks Dutch | | |
#11141 05/25/2003 1:28 AM | Joined: May 2001 Posts: 1,907 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,907 | St. Elmo's Fire on an Advance Design? I would look at the plastic insulator that goes through the body of the distributor with the conducting bolt inside it. I don't know if you can buy that insulator alone. There are more knowledgable folks than me, especially Randy (fifthave) one notch down in the Electrical Bay. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#11142 05/25/2003 1:50 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Wally may be right on this one. Look at the insulator lug which goes through the side of the distributor housing Make sure the connector ends for the points and the condenser are not bent over and close to touching the distributor housing. They may be pushed on when the cap is put on. they can look ok(the connections) but make contact or almost when the cap is on with the edge of the cap pushing them down.
#11143 05/25/2003 6:05 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | The distributer is supposed to have a ground wire between the block and one of the screws on the distributer body.Without the wire, the path to ground is through the sloppy vacuum advance linkage and or the oily distributer shaft,later advances have a brass tab supposedly to help ground it without a additional wire. | | |
#11144 05/25/2003 6:20 PM | Joined: Jan 2003 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2003 Posts: 33 | Thanks for the advice, Wally, Mechainiac and Tony (  I heard you had a good time in Rochester) and will check it out this afternoon. Keep you posted. Dutch | | |
