7 members (Otto Skorzeny, Samantha, MNSmith, Phak1, cmayna, CATMAN, Gray_Ghost), 62 guests, and 1 robot.
Topics128,154
Posts1,056,850
Members48,456
Hi, I was timing my '54 3800 and saw sparks flying on the vacuum advance bracket :confused:
What would be the reason that this happens?
Thanks Dutch
St. Elmo's Fire on an Advance Design? I would look at the plastic insulator that goes through the body of the distributor with the conducting bolt inside it. I don't know if you can buy that insulator alone. There are more knowledgable folks than me, especially Randy (fifthave) one notch down in the Electrical Bay.
Wally may be right on this one. Look at the insulator lug which goes through the side of the distributor housing
Make sure the connector ends for the points and the condenser are not bent over and close to touching the distributor housing. They may be pushed on when the cap is put on. they can look ok(the connections) but make contact or almost when the cap is on with the edge of the cap pushing them down.
The distributer is supposed to have a ground wire between the block and one of the screws on the distributer body.Without the wire, the path to ground is through the sloppy vacuum advance linkage and or the oily distributer shaft,later advances have a brass tab supposedly to help ground it without a additional wire.
Thanks for the advice, Wally, Mechainiac and Tony ( wink I heard you had a good time in Rochester) and will check it out this afternoon. Keep you posted. Dutch
