1 members (Samantha),
45
Mod | | | Forums66 Topics128,179 Posts1,057,159 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 20 'Bolter | | 'Bolter Joined: May 2015 Posts: 20 | (1949 1-ton with 59-62 261)
First off, I'm not 100% sure the rad is original, but the lower hose outlet is 1.5" diameter. On the water pump it's 1.75". I'm having trouble finding a replacement hose that has different size ends... Can anyone point me in the right direction?
Thanks, Grandpa's Dump Truck | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Grandpa's Dump Truck,
I think someone in the past posted a hose with the two different diameter-ends.
I had to buy: 1. the larger 261 hose (to fit the 261 water pump) 2. the smaller truck hose: to cut off the radiator end of the hose and place that end inside the 261 hose-end. This worked fine for many years. | | | | | Joined: May 2015 Posts: 20 'Bolter | | 'Bolter Joined: May 2015 Posts: 20 | Hmmm. Never thought of using a piece of the smaller hose as a bushing. I do have both sizes so I'll try that and see if I like the result.
Thanks for the tip!
(If anyone knows of a hose that is moulded in the correct end sizes, I would still be interested to know...) | | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | Jim Carter sells the lower hose for use when you replace a 216 with a 235. I bought one for my 50 COE and worked fine, although the hose seems a little flimsy and thin walled. This has worked fine for 3 or 4 years. This may be the same size as the 261, best to call them and check or research whether a 261 water pump is the same or same inlet diameter as a 235. Kent | | | | | Joined: May 2015 Posts: 20 'Bolter | | 'Bolter Joined: May 2015 Posts: 20 | I had purchased a set from chevsofthe40s: https://www.chevsofthe40s.com/detai...Set_2_GM_Script_With_Original_Style.htmlThe "lower" hose was the right diameter for the upper fittings on both the radiator and thermostat housing, so I cut it into a 90° section and installed it as my upper hose. The "upper" hose in that kit is too small for any of the fittings in my truck. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Your radiator has a year stamped on it if its original. Its on the engine side on the top part.
I just purchase the Jim Carter fitted hoses for 1950 and deal with what I get. The small top one DOES fit, but you have to go thru HELL to get it on. Once it's on the thermostat housing, life is good. The bottom one is too big for the water pump end, but a hose clamp works wonders. I agree it would be nice to have decent fitted hoses. Let us know if you find them. My water pump is a 1953 short shaft and the 235 and 261 inlet for the thermostat is the same from 55-62. Maybe earlier too, but not sure. | | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | Buy a flex hose to fit the larger diameter. Be sure it has a reinforcing wire to prevent collapse because it will be on the suction side of the water pump. Cut a 2" long sleeve of the smaller diameter hose and install it DRY on the radiator nipple. Slip the larger hose end over the sleeve, also dry with no attempt at sealing it, and use a worm screw type clamp, tightened firmly. I have used this method on racing cooling systems with 20 LB. pressure caps without any issues. No need to pay ridiculous prices for a custom hose when low tech will get the job done, unless you're some sort of anal-retentive purist. We don't have any of those folks on this forum, do we? Jerry
| | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | Simma down now Professor.
Allen Yeah, well, that's just like, you know , your opinion, man - The Dude
1948 Chevy 3600 - goal Original restoration, Current Stage 1 - Disassembly and getting body in primer 1954 GMC 3100 goal Hot Rod, Current Stage 1 - Get body in primer 1931 Ford Model A 5 window Coupe - Old Skool Hot Rod 1945 Ford 2N Tractor - Runs great 1964 Ford 2000 Tractor - Use it every week 1974 Stingray Corvette
| | | | | Joined: Mar 2010 Posts: 10,308 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,308 | Buy a flex hose to fit the larger diameter. Be sure it has a reinforcing wire to prevent collapse because it will be on the suction side of the water pump. Cut a 2" long sleeve of the smaller diameter hose and install it DRY on the radiator nipple. Slip the larger hose end over the sleeve, also dry with no attempt at sealing it, and use a worm screw type clamp, tightened firmly. I have used this method on racing cooling systems with 20 LB. pressure caps without any issues. No need to pay ridiculous prices for a custom hose when low tech will get the job done, unless you're some sort of anal-retentive purist. We don't have any of those folks on this forum, do we? Jerry Why just today I experienced lack of anal-retentiveness on my personal original equipment. I would not, however, describe it as pure.
| | | | | Joined: May 2015 Posts: 20 'Bolter | | 'Bolter Joined: May 2015 Posts: 20 | I'll look for the year stamp - might help with the search, thanks. This one from Jim Carter looks like it might be what I need: http://www.oldchevytrucks.com/cart/product.asp?prodid=ME239Has anybody tried it? I will see what I can rig together with what I have for now in the interest of getting the truck going. I am not anal retentive, just OCD. Having something on there that doesn't feel right will bug me and if I can spend $20 to get the proper one, I'd rather do that.  BTW, 52Carl: Gross. | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 |
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | As Jerry said, make you a bushing. You local parts store should also have bushings in stock for that purpose. Gates makes these and perhaps other brands make them as well. The parts store I worked in keeps these still due to ill fitting hoses or engine conversion. Works well, and looks like a factory hose when done. Here's what they look like. http://www.amazon.com/GATES-BELTS-HOSES-26390-Reducer/dp/B000CRHKSG
I bet the JC hose will cost no more than the hose-end placed within-a-hose solution suggested by me and others (maybe shipping from JC makes the hose-end placed within-a hose a better $$). | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | I have tried it. Its a little loose at the water pump end but a clamp makes it leak proof so not THAT loose. The top one that is very small works too, but its a bear to get on. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I used copper pipe for straights and elbows of appropriate sizes on my '37 GMC, only used short sections of rubber on the ends, so no problem replacing the short sections, soldered all the copper sections.
| | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | The Jim Carter hose is what I referenced above, and yes, I tried it and it works.
Also, I believe that the thermostat outlet to the radiator on a 235 is larger than a 216, so Deve, you may need to change over to the smaller 216 outlet to fit the upper hose. I had that problem with the 235 in my 1942 pickup with original radiator until it dawned on me to change it out. Fixed the problem. Kent | | | | | Joined: May 2015 Posts: 20 'Bolter | | 'Bolter Joined: May 2015 Posts: 20 | Thanks for all the input everyone!
I think for now I'll just make something up, and when I have a few more parts on my shopping list I will order the proper hose from Jim Carter since shipping to Canada sucks. | | | | | Joined: May 2015 Posts: 20 'Bolter | | 'Bolter Joined: May 2015 Posts: 20 | By the way, here is a picture of the upper hose I made out of the chevsofthe40s bottom hose: https://flic.kr/p/vYLaLX | | |
