3 members (MNSmith, Shade Baby, Tronman), 112 guests, and 1 robot.
Topics128,051
Posts1,055,762
I know this has been hashed over before but do the 6" 2200 lb rated eye bolts from tractor supply work, removing the 2 head bolts and screwing those back in ? does it work without removing the rocker Assembly? I was confused. Anybody here used that procedure?
As long as they're forged eye bolts (not the rolled ones with an open gap) with a 1/2"-13 thread they should work just fine. I'd suggest cutting a short sleeve of pipe to slip over the eyebolt, and tighten it down snug rather than just letting the bolt float free in the thread. As long as the lift chain doesn't put any strain on the rocker shaft or rocker arms, it won't hurt to leave the rocker assembly installed. I'd suggest clevises to attach the chain to the eyebolts.
I agree with the forged eyelet part. I have been too apathetic to do the sleeve of pipe, but that is a really good idea. Here is how I like to do it.
[img]http://www.surfacezero.com/g503/data/3596/2013-07-14_12_24_311.jpg[/img]
Paul
Lots more pictures
Gas Pumper
Gas Pumper
Is two eye bolts sufficient to carry the weight without damaging the engines threads for the 90 pound torque head bolts? You probably have about 700 pounds there or so? I wonder how the math works out.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
How would using 2 eye bolts be any different than any other type of bolt to attach a chain to the engine?
BTW, with 2 bolts, the stress on each threaded hole would be 1/2 of the weight lifted.
Carl
Most people just bolted the chain links under the head bolts and hung the whole mess on about 2 or 3 threads. Now, that's dangerous! Eyebolts are plenty strong as long as they have at least 5 or 6 threads engaged.
Gas Pumper
Gas Pumper
I know Carl. 300+ pounds on each tapped head bolt hole, so I am wondering if four wouldn't be better for the longevity of the engines head torquing? If everyone feels two is enough, thats great, just bringing it up.
I see people (including a local machine shop) pick them up with the intake/exhaust manifold and just cringe. Many an exhaust manifold destroyed that way.
Deve
The Think Tank
When a head bolt is torqued up, it provides a clamping force much greater than the weight of that motor. I am responding to the question about lifting with only two bolts.
1951 1 Ton Completed
pix love it
Thanks everyone for the quick responses ...eye bolts it is.......just wondering if you pull the rocker assembly off does that require adjusting lifters and does the oil tube come off with it?....i have never messed with the 6 cylinders
The 1941 technical manual describes the way I posted...unless we are smarter now, it worked back then.
Lots more pictures
Gas Pumper
Gas Pumper
So from what Fred is saying, put a washer and a nut on the bolt threads and tighten it down to the head (or use Jerry's pipe idea) to strengthen yes?
Deve
The Think Tank
Yes, disturbing the rocker assembly requires valve adjusting, but that needs to be part of the maintenance routine anytime any sort of tuneup is done, when the phase of the moon changes, and a bunch of other times. Valve adjustment should be so ingrained into a stovebolt mechanic's routine he can do it in his sleep, hung over, or any other time I can imagine. These old rigs need a LOT of TLC. Setting points, adjusting timing, adjusting valves, filing and re-gapping spark plugs- - - -that's how us old geezers paid the rent and the grocery bill back when the labor rate was $7.50 an hour!
Gas Pumper
Gas Pumper
http://www.mcmaster.com/#eyebolts/=y1if8d
Pricey, but made for the job.
Deve
The Think Tank
Great Ideas here thanks a bunch!
Bought this equalizer bar from HF, I had good luck with it leveling the load. My truck was frame-off so I came in/out with trans installed.
https://www.flickr.com/photos/advance-design_parts_co/8129078353/in/album-72157631867396207/
I have the exact same equalizer bar, and I don't know how I lived without it years ago.
Gas Pumper
Gas Pumper
me three! great stuff!
Deve
The Think Tank
