2 members (Gdads51, moparguy),
96
Mod | | | Forums66 Topics128,180 Posts1,057,068 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2015 Posts: 37 'Bolter | | 'Bolter Joined: Apr 2015 Posts: 37 | I am having trouble pressing my new timing gear on the new cam shaft. I have already damaged one. The gear is not pressing on straight by the keyway. Any tips or any one else have a similar problem. Thanks | | | | | Joined: Feb 2004 Posts: 29,868 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,868 | Try filing the top of the key a little to keep it from dragging on the gear hub. The key is more of an alignment device than an actual drive lug- - - -the press fit carries most of the driving load, so the key does not have to be a perfect fit in the slot. Also, a little anti-seize compound on the parts will help them slip over each other without compromising the fit. An aluminum gear can be heated to about 250 degrees and it will virtually fall into place- - - -I don't think I'd try that with a fiber gear, however. Jerry
| | | | | Joined: Apr 2015 Posts: 37 'Bolter | | 'Bolter Joined: Apr 2015 Posts: 37 | I am using an aluminum gear. thanks
| | | | | Joined: Feb 2004 Posts: 29,868 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,868 | Put the gear into an oven at 250-300 degrees for 1/2 hour, then use welding gloves and a dead blow mallet to install it instead of a press. Just handle it quickly, as it will begin to shrink as soon as it contacts the camshaft hub. Don't forget to install the thrust plate first! I've also done the heating with a Propane torch right at the workbench by placing the gear on a piece of steel plate and heating inside the bore hole until a drop of water flashes to steam instantly when it's dripped onto the gear at the outer edge. Jerry
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | One thing I learned the hard way was to put pressure only on the hub part. They are not very sturdy. | | |
