7 members (55Delray, Steve L., Bill Hanlon, MickeyP, WICruiser, Bucker, 1 invisible),
64
Mod | | | Forums66 Topics128,206 Posts1,057,435 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 84 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 84 | just curious fellow ad junkies if a 1948 fleetline front suspension will work in a 54 chevy and has anyone done this before? why are the 48 fleetlines 5 lugs but 54 chevy are not lol
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Don't see why it wouldn't work, no different than any other IFS swap, you'll have to make it fit. Steering might be a little different to setup, if you use the stock linkage. You won't really gain much handling and brake wise compared to the more common Camaro or S 10 swap. If the one you're looking at is 5 lug, though, it's not a '48. Chevrolet cars did not go 5 lug until the '49s.
Bill Burmeister | | | | | Joined: Jan 2002 Posts: 84 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 84 | ok so it is a 49 the frame measures the same width and length. It has about four five bolts and should bolt up with a few modifications I think. has anyone done this swap? just curious? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Why would anyone want to? There is nothing wrong with a properly maintained truck suspension. What do you expect to gain by installing an antique car suspension? | | | | | Joined: Aug 2014 Posts: 218 I have more zippers then a pair of cargo pants | | I have more zippers then a pair of cargo pants Joined: Aug 2014 Posts: 218 | Edit - Correct Link to Swap Personally if you're wanting to do this type of swap I'd use the 49-54 car suspension since it's the same as the Corvette. HAMB link to info on swap.
~ Joe Donate Blood, Plasma, Platelets and Sign Your DONORS CARD. The Life You SAVE Might Be Someone You Know and LOVE. Two possibilities exist: Either we are alone in the Universe or we are not. Both are equally terrifying. ~ Arthur C. Clarke | | | | | Joined: Jan 2002 Posts: 84 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 84 | yes it is a 49 and it all matches up perfect, plus it is cheaper and less modifications to make. Thank you for the link it solved most of my questions and since the parts were free, including a rear-end and drive shaft. I guess all my questions are answered1 again for you fellow bolters or novices there is really only one place to come to for info and or advice. www.stovebolt.com if they dont know I bet someone they do know does lol | | |
