2 members (dt235sd, Peggy M),
76
Mod | | | Forums66 Topics128,130 Posts1,056,713 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2014 Posts: 19 New Guy | | New Guy Joined: Dec 2014 Posts: 19 | '49 3100 with after market turn signal..Indicator light on unit started staying on all the time..Blinkers, brakes,flasher, headlights all work properly..Replaced unit with new one..Same problem..Any ideas?
Thanks, Bill | | | | | Joined: May 2015 Posts: 236 Shop Shark | | Shop Shark Joined: May 2015 Posts: 236 | Do you have the wiring diagrams for the aftermarket indicator, it is hard to troubleshoot not knowing how it is wired.
Baking in the nice desert sun, breathing life back into a 48 3800 5 window. | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Your flasher may be the problem. One terminal "P" on a 3 terminal flasher is for the pilot (indicator) light.
Ed
| | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | Check to see if a short on something is grounding through the indicator light | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I just had this problem and it was a bad flasher. There is nowhere in the wiring that a short or bad connection can cause this problem | | | | | Joined: Dec 2014 Posts: 19 New Guy | | New Guy Joined: Dec 2014 Posts: 19 | Thanks to all for the help..It was a bad flasher..
Bill | | | | | Joined: Mar 2005 Posts: 155 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 155 | Had to replace the dead flasher on my after-market signal unit within two months after installing. Another bonus of replacing the junk flasher with a decent HD unit like (Advance Auto/Novita EL13/$15.00) is a nice loud “Tick Tock” that is more like original. | | |
