1 members (Hotrod Lincoln),
41
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 367 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 367 | I am getting ready to start work on my cab and was thinking a dolly may be a good idea . Has anyone built one? what size rollers would be good steel or rubber? Got a pic of one you made send to me Thanks | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I am a cheap-and-easy guy.
I have used this "dolly" (actually, two dollies) with two cabs (1954 Chev/GMC):
Two pieces of 3'-4' long 6"x6" rough-cut (cheap) lumber (no more than the length of the cab bottom) (I had scrap pieces on-hand - 4x4 would probably do the job) 4 metal wheels (with swivels) from Harbor Freight (cheap)
Screw/bolt two wheels to the bottom of each of the 6x6s (4x4s)
Place the rolling 6x6s under the cab (with the front of each 6x6 under the frame-mount bolt hole). Lag-bolt the cab to each 6x6.
If there are no cab-mount attachment holes in your cab, ignore this suggestion (you did not post the year - maybe 1959 or 1936?)
Some people impress their friends with impressive/expensive (time & $$) devices - I impress my friends with good-working solutions that are cheap-and-easy (and safe). | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If you are looking for a rotisserie, here are some ideas: truck cab rotisserie I did not need a rotisserie - I first worked on the bottom of the cab - tipping it forward onto the firewall (works fine on 47-55 cabs). | | | | | Joined: Jul 2009 Posts: 367 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 367 | Tim sorry about the trucks age itsa 59 just happen to have 2 3x6 pt post laying in yard and harbor freight is near. like the steel wheels as my driveway is asphalt . I think a 4" dia wheel would work. ijust want to be able to move it around and maybe on to a trailer to welder. Anybody have a guestament of the weight of a cab? need it to be strong enough to have the doors on for fiting. | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Cab is not heavy. Its the beer for the four friends that is heavy. Doors or no doors its a four man lift with one extra to balence and position the dolly. | | | | | Joined: Jul 2009 Posts: 367 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 367 | Thanks for the weight up date. I don't have four friends so was gona use a bobcat to lift it but was interested on the size wheels. I was guessing 500 lbs max. | | | | | Joined: Jul 2014 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 186 | I used a pallet with four casters mounted to the corners. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Since wheels are rated for each wheel, and a cab wouldnt weigh over 400 pounds, you can get away with 125 pound rated wheels.
The reason for the cab cart for me was to go from sandblasting to finish paint in one tool. This meant putting 8 inch wheels so I could hitch up the cart and pull it outside with my lawn tractor. Turned out to be good on concrete then too. Once you go with that large of wheel, weight isn't a factor since they are usually rated at about 400 pounds each. | | | | | Joined: May 2006 Posts: 934 'Bolter | | 'Bolter Joined: May 2006 Posts: 934 | I'm impressed, Tim!  Tom | | | | | Joined: Oct 2014 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2014 Posts: 34 | I have some 2X12s im going to use. Put 2 of them together to make a beam and then put the castors on the bottom and then 4x6 rails for underneath the cab to give it alittle more height. | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | I just doubled up a couple of 2x4's on cheap Harbor Freight casters. When I needed more height I sat on some jackstands. Worked for me. However I used what I had and would recommend using what you have lying around and put the money saved into the truck....lol. Have fun and good luck Dan | | |
