6 members (John L., Otto Skorzeny, Bill Hanlon, Maybellene, 2-Ton, klhansen), 65 guests, and 4 robots.
Topics128,042
Posts1,055,501
Members48,424
#1112307 07/07/2015 2:25 PM
anybody encounter the situation where the leafspring bushings are so worn out that the pin/bolt actually wears into the leafspring eyelet and wears away part of the leafspring material itself, thus oblonging the hole? im wodering if I could put in a new bushing, then fill the void around the outside of the bushing with a jb weld type material. thoughts??
I would replace the springs, again it is how bad the wear is. But if you trying to build up elongated holes then the springs themselves had had a lot of bounce worn out of them, then to me that says replace.
Baking in the nice desert sun, breathing life back into a 48 3800 5 window.
Moderator, Electrical Bay
Yes, this isn't all that uncommon. Before I forget, you can get genuine AC Delco eye bolts/bushings on Amazon. They're original quality and cheaper than the other suppliers by about $10 each. I mentioned this about a month ago and am using these in my 1952 1/2 ton.
As for the hole being oblong, you could do what you've suggested. It may not stay in place or stay solid for long, however. If you have a propane torch, here is another idea: Stay-Brite silver bearing solder is one of the hardest solders available and it melts at something around 500 degrees. This temp shouldn't be enough to alter the temper of your spring nor damage your bushing. Just be very careful not to get any inside the bushing The company claims Stay-Brite 8 is stronger than a brazed joint in some cases. At any rate, if you can use some imagination and figure out how to fill the gap with this, it might stay in place longer. The eye bolt and its bushing take a lot of vibration after all. Good luck!
Jon
~ Jon
I don't think JB Weld will do anything for you.
1951 1 Ton Completed
Riding in the Passing Lane
This is the main leaf. If it breaks it can cause some serious results.
1972 Chevy c10 Cheyenne Super
New main springs are cheap insurance. They may improve your ride height as well.
Carl
A good place to look if you start thinking new springs.
https://www.eatondetroitspring.com/
There is a Spring Service place in Greenville, S.C. as well on White Horse Rd.
From the description given, if it were me, replacement would be done.
thanks guys. looks like i'll be getting new springs.
St. Louis Spring is another good place to get springs.
St. Louis Spring
Samantha
1954 Chevy 3100
Picked from the Field
Follow in the DITY
