1 members (Hotrod Lincoln),
130
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | 216 was running perfectly, then all of a sudden it quit. Restarted, but needed chock to stay running...well, idling fast. Throttle is not smooth, but rather touchy/jumpy. Any suggestions on where to start troubleshooting. My thoughts:
1. Fuel pump. 2. Trash in carb idle circuit.
I don't think carb is flooding as chock is required to keep it running. Still starts easily, so probably not ignition. | | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | Trash in the idle circuit is a possibility, however:
Carburetors go bad over years, even decades.
Ignition systems go bad in the blick of an eye, especially the electronic ones.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Feb 2004 Posts: 29,821 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,821 | Try revving the engine up and clap your hand or a big rag over the air horn, several times if necessary, to see if you can flush the crud out of the internal passages. Sometimes that draws a big slug of liquid gasoline through passages that normally only see vapors or gas/air emulsion. Can't do any damage, and sometimes a small chunk of trash will get flushed away. Jerry
| | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Thanks Hotrod, that did the trick...all is well again.
| | | | | Joined: Mar 2010 Posts: 10,282 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,282 | Yep. That's why they let him stay around here. In addition to this kind of incite, there is also his mild mannered temperament, always polite discourse, and his caring and comforting demeanor. Let me know if I left anything out.  Carl
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | You left nothing out, Carl. You were almost poetic, in using incite instead of insight to describe Jerry's style of posting assistance. Your double entendre was almost poetic. | | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | That's a sweet fix Jerry.
Allen Yeah, well, that's just like, you know , your opinion, man - The Dude
1948 Chevy 3600 - goal Original restoration, Current Stage 1 - Disassembly and getting body in primer 1954 GMC 3100 goal Hot Rod, Current Stage 1 - Get body in primer 1931 Ford Model A 5 window Coupe - Old Skool Hot Rod 1945 Ford 2N Tractor - Runs great 1964 Ford 2000 Tractor - Use it every week 1974 Stingray Corvette
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I just couldn't leave this alone. Such BIG words, some of us are very well educated. Jerry, I think they are trying to 'roast' you in absentia. But to what Mr. Lane stated...+1.
| | | | | Joined: Feb 2004 Posts: 29,821 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,821 | Is a duck's back waterproof?  Jerry
| | | | | Joined: Mar 2010 Posts: 10,282 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,282 | Is a duck's back waterproof?  Jerry Apparently I left out habitually humble. Carl
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Is a duck's back waterproof?  Jerry  | | |
