| | | Forums66 Topics128,130 Posts1,056,717 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2002 Posts: 158 knuckle head | | knuckle head Joined: Sep 2002 Posts: 158 | 230-250 distributors are known for wear. The shaft gets side to side play that messes with the point gap. It's said the bushing at the top wears out...I have several housing here and none of then appear to have bushings. So does the shaft run directly on the aluminum housing bore? | | | | | Joined: Feb 2004 Posts: 29,838 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,838 | With a lathe and a couple of chucking reamers, it would be easy to install an upper bushing made of oilite bronze. If enough people are interested, I might be willing to tool up and produce a few bushed housings. Jerry
| | | | | Joined: Sep 2002 Posts: 158 knuckle head | | knuckle head Joined: Sep 2002 Posts: 158 | I was mistaken,one all the crud was removed there is a top bushing . I had bought a Cardone supposedly rebuilt distributor for 35 bucks...The advance/cam and shaft look like something made in India and it was sticking in the full advance position... but the distributor housing had a bushing top and bottom like Hot Rod Lincoln is talking about. I fitted the old GM guts into the Cardone housing and it's all good as new now...
