3 members (Otto Skorzeny, moparguy, DaveV), 112 guests, and 1 robot.
Topics128,111
Posts1,056,244
Members48,437
#1111878 07/05/2015 4:30 AM
Having successfully removed the spring shackle side plates (the BFH and large punch worked well) and the pins, the next challenge is removing the clearly worn out bushings.
I constructed the bushing puller described in the article in this forum, and it actually started to work, pulling the old bushing out about 3/8". At that point it stopped working, with the bolt in the puller spinning in the bushing.
Do I need a bigger bolt that fits the bushing tighter?
Should I apply heat to the fitting holding the bushing?
Can I use the new bushing and a hammer to drive out the old bushing?
Thanks!
Trooper Jeff
If I can't drive my truck, fetch my horse
"Courage is saddling up even though you are scared to death" - John Wayne
Not quite as generic as the other means of removing/pressing the
front and rear bushings but this was my solution. Perhaps you
can find something you can use in these pictures:
http://www.pbase.com/dennygraham/image/122328118
dg
Denny G
Sandwich, IL
Moderator, Electrical Bay
You may need a larger diameter bolt. I've tried this using things like 5/16" all-thread and it never worked for me. Large in this case can be good. Good luck. Using a hammer and the new bushing to drive out the old one sounds to me like it might just ruin the new one?
Jon
~ Jon
My Blog
Originally Posted by Pre '68 Dave
I like that way as well.
I lucked into some grade 8, 3/8" all-thread somehow. It won't strip out like the soft steel which most all-thread seems to be made of. I use the 1" long coupler nuts to spread the work around along all of the additional threads compared to a standard 3/8 nuts. If I have a bushing that is extra stubborn, I use a propane torch to warm up the spring end or the frame mounted bushing bracket a bit to create a little expansion.
Carl
