0 members (),
144
8
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 430 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 430 | I know that there has been many discussions about the windshield crank mechanism on the internet. I am in the process of repainting my 46 2-ton and I am missing some pieces on my windshield crank out assembly. I have the gear box, but the stainless strip is long gone and the gears are worn. I will fabricate what I need for my truck, but it brings up the question of what do other people do?
I run a fabrication shop and I have just finished up a bolt on brake kit for the bigbolts and wanted to gauge some interest in if I should make brand new units that do not require a core or to be rebuilt? Something that I can machine out of aluminum and make it much stronger than it is now.
I am willing to invest in the design and engineering in this if there are a lot of people out there that are needing these and no one is supplying them?
Please provide some feedback.
Thank you,
| | | | | Joined: Nov 2010 Posts: 430 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 430 | Harold, I will contact him. I was thinking about reproducing the whole regulator, strap and all!
I can not find where anyone is making them? | | | | | Joined: Oct 2012 Posts: 7 New Guy | | New Guy Joined: Oct 2012 Posts: 7 | Good Day I am also restoring a 41 and need a windshield regulator ..have you had any progress on a repro. design. thanks much Mur41 | | | | | Joined: Mar 2013 Posts: 176 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 176 | The only thing wrong with mine is the little brass piece that keeps the gears in alignment. I can make a new one, but if you need the dimensions of the strap I could get them for you. | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Bow Tie Bits rebuilds them.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Mar 2011 Posts: 107 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 107 | If you can figure out how to replicate the stainless strap I think there will be some demand, that seems to be the part that makes a core "rebuild able". | | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 | Randy, I have ben trying for months to get hands on a strap. I have even thought about fabricating my own, if I could gets full specs on the material, esp thickness. I haven't even been able to find a broken strap. Please let me know if you have any luck making them. Bob
BobS46
