| | | Forums66 Topics128,077 Posts1,056,032 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2013 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2013 Posts: 34 | Having successfully removed the spring shackle side plates (the BFH and large punch worked well) and the pins, the next challenge is removing the clearly worn out bushings.
I constructed the bushing puller described in the article in this forum, and it actually started to work, pulling the old bushing out about 3/8". At that point it stopped working, with the bolt in the puller spinning in the bushing.
Do I need a bigger bolt that fits the bushing tighter? Should I apply heat to the fitting holding the bushing? Can I use the new bushing and a hammer to drive out the old bushing?
Thanks!
Trooper Jeff If I can't drive my truck, fetch my horse "Courage is saddling up even though you are scared to death" - John Wayne
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Not quite as generic as the other means of removing/pressing the front and rear bushings but this was my solution. Perhaps you can find something you can use in these pictures: http://www.pbase.com/dennygraham/image/122328118dg
Denny G Sandwich, IL
| | | | | Joined: Mar 2014 Posts: 4,486 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,486 | You may need a larger diameter bolt. I've tried this using things like 5/16" all-thread and it never worked for me. Large in this case can be good. Good luck. Using a hammer and the new bushing to drive out the old one sounds to me like it might just ruin the new one? Jon
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 |
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | | | | | | Joined: Mar 2010 Posts: 10,279 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,279 | I lucked into some grade 8, 3/8" all-thread somehow. It won't strip out like the soft steel which most all-thread seems to be made of. I use the 1" long coupler nuts to spread the work around along all of the additional threads compared to a standard 3/8 nuts. If I have a bushing that is extra stubborn, I use a propane torch to warm up the spring end or the frame mounted bushing bracket a bit to create a little expansion. Carl
