2 members (carbking, TUTS 59),
108
Mod | | | Forums66 Topics128,029 Posts1,055,416 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 71 Member | | Member Joined: Mar 2004 Posts: 71 | I'm finishing up the body work on my 49 1/2 ton before it goes to the paint shop. I need to finish door jams, inside of doors, etc. Painter will only be doing exterior. It would be much easier to do my part with the doors off. I'm thinking about removing them at the hinge points on the door since that only affects fore and aft adjustment when they go back on. Am I getting ready to do something that I will regret? i.e. getting the doors adjusted properly without an enormous amount of work. Thanks | | | | | Joined: Nov 2003 Posts: 41 Member | | Member Joined: Nov 2003 Posts: 41 | I would take them off. Yes you will probably have fun adjusting the doors when you put them back on but it will look alot nicer if you finish the jams with them off. Just my $0.00002 worth.
Joe K.
1963 Chevy Stepside 350 with 3 on the tree. 1960 Chevy Bel Air 35k original miles 1991 GMC Syclone #1557 1992 GMC Typhoon #0261
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | If you drill a small hole all the way through the hinge and the body (or door) before you take it off you can use the drill bit as an alignment tool when you go to put it back on. It is very easy that way.
