5 members (carbking, RLB, Woogeroo, Mike Lee, stlcardinalsguy), 59 guests, and 3 robots.
Topics128,186
Posts1,057,321
Members48,469
V
V Offline
Were gas tank filler tubes painted on the old Chevy pick-ups - specifically the Art Deco pick-ups? If so, were they black or body color?
My son's 1946 2 ton filler neck painted Brewster Green the same as the truck body.
How many horses pulled that there 2 ton 1846 carriage? smile
(Just yanking your chain there buddy.)
V
V Offline
Is the filler neck painted even on the inside of the cab?
Depends on the size of the horse. chug
The first answer was free.
What do you got to give? grin
My son has the truck out on the North Fork right now so I can not measure and say exactly how far down the paint goes on the filler neck.
Though it definitely goes past the filler neck grommet so no bare metal is seen on the outside of the cab. Though the paint did not go all the way to the tank if I remember right.
The truck may be coming home today.
Mine was body color to the cab and raw metal on the inside with a hint of overspray.
Dan
Dan
Same with my 1941 trucks (original paint).
Dan
Exterior color overspray or interior color?
1950, 3604, original color was mariner blue:
http://www.pbase.com/dennygraham/image/149612029
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
V
V Offline
Looks like the filler necks were painted ahead of time at the factory to match the cab, eh?
V
V Offline
The next question then is: was the filler neck seal retaining ring also painted to match the cab, or was it painted black on the '42-46 models that had that type of seal?
It was painted body color.
Harold
Harold
Not Art Deco , but my advanced design also had remnants of exterior color inside.
V
V Offline
Thanks. I really appreciate all the input!
1946 2 ton tank filler neck was painted 3" into the cab.
The ring that holds grommet on the filler neck painted the same as the body.
