| | | Forums66 Topics128,037 Posts1,055,580 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2015 Posts: 285 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 285 | I will be plumbing the brake lines on my '53 GMC 100. It has a manual master cylinder and drums all around. What size of brake line should be run with this setup? | | | | | Joined: Sep 2013 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2013 Posts: 93 | Mimic the stock. Drum brakes move more fluid than disc. That is why the rear line is 1/4 inch. Can't go wrong with what the General specified from the factory.
1947 GMC Truck 5 window, Long Bed 2008 Corvette Roadster 2008 Harley Davidson FXDL 2011 F150 Ecoboost 4X4 2015 Subaru Outback AWD "only the strong survive"
| | | | | Joined: Feb 2015 Posts: 285 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 285 | The stock lines, for the most part, are not on there. Someone added lines, but I wanted to make certain to run the correct diameter. If I understand your post correct, you are saying the stock lines are 1/4 in., correct? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I can't say that GMC is the same, but according to the manual for Chevrolet, the lines are 3/16" except for the line from the MC to the junction block and the cross pipe for the rear axle.
Bill Burmeister | | | | | Joined: Feb 2015 Posts: 285 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 285 | ^Thanks! The junction block is what distributes the brake fluid to the front and rear, correct? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 |
