Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 95 guests, and 0 robots.
Topics128,274
Posts1,058,433
Members48,490
#1111370 07/02/2015 3:07 PM
I will be plumbing the brake lines on my '53 GMC 100. It has a manual master cylinder and drums all around. What size of brake line should be run with this setup?
gusco #1111371 07/02/2015 3:15 PM
Mimic the stock. Drum brakes move more fluid than disc. That is why the rear line is 1/4 inch. Can't go wrong with what the General specified from the factory.
1947 GMC Truck 5 window, Long Bed
2008 Corvette Roadster
2008 Harley Davidson FXDL
2011 F150 Ecoboost 4X4
2015 Subaru Outback AWD
"only the strong survive"
gusco #1111378 07/02/2015 4:10 PM
The stock lines, for the most part, are not on there. Someone added lines, but I wanted to make certain to run the correct diameter. If I understand your post correct, you are saying the stock lines are 1/4 in., correct?
gusco #1111424 07/02/2015 7:54 PM
I can't say that GMC is the same, but according to the manual for Chevrolet, the lines are 3/16" except for the line from the MC to the junction block and the cross pipe for the rear axle.
Bill Burmeister
gusco #1111434 07/02/2015 8:49 PM
^Thanks! The junction block is what distributes the brake fluid to the front and rear, correct?
gusco #1111436 07/02/2015 8:54 PM
Yes.
Bill Burmeister
