1 members (1955 1 Series),
64
Mod | | | Forums66 Topics128,169 Posts1,057,102 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2014 Posts: 106 Shop Shark | | Shop Shark Joined: Jun 2014 Posts: 106 | I need a new gasket for the rear differential. If I am reading things correctly, it looks like the differential cover gasket was used up into the 60s.
No one has anything in stock nearby and I don't want to order one only to have it be wrong.
It looks like I need FelPro gasket #RDS5088.
Can anyone confirm this part number or provide the correct one?
Thanks, Justin | | | | | Joined: Dec 2008 Posts: 901 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 901 | I have an extra Fel-Pro rear axle housing set. (only comes with one gasket). Part # RDS 4304 (says it replaces part #3731305). For my 55.2 3100 truck. Says it fits: Chevrolet 6 1935-1936. Pontiac 6 1935-1936. Chevrolet truck 1/2,3/4,1 ton 1937-1963. GMC truck 1/2 ton 1939-1966. Here's a picture. http://autoplicity.com/1653923-fel-...7Kcn18Dx06w7d7cOBsxBoNih7LhiUhoCA6vw_wcBHope this helps.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Jun 2014 Posts: 106 Shop Shark | | Shop Shark Joined: Jun 2014 Posts: 106 | Thanks Shaker,
I believe that is the gasket for the front of the rear housing. Does that sound correct?
I am looking for the gasket on the back side of the housing under the rear cover. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Most of us use RTV for that these days. | | | | | Joined: Dec 2008 Posts: 901 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 901 | Justin, I used it as a cover gasket. I really don't know if it's for the pumpkin, or the rear cover.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Jun 2014 Posts: 106 Shop Shark | | Shop Shark Joined: Jun 2014 Posts: 106 | Brian,
After comparing it to the picture of mine it does look correct. Thanks for the help.
You said, "Says it fits: Chevrolet 6 1935-1936. Pontiac 6 1935-1936. Chevrolet truck 1/2,3/4,1 ton 1937-1963. GMC truck 1/2 ton 1939-1966."
What is your source for this information? | | | | | Joined: Dec 2008 Posts: 901 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 901 | Brian,
What is your source for this information? Justin, the information, came from the back of the package the gasket came in that I have here in my hand. I just e/mailed you a picture, of the package.
Thank you for the picture. Amazing that even on the Fel-Pro site they don't list that part as being applicable to the '37 1/2T.
I appreciate the information immensely. Almost got Ol' Clyde back on the road! | | |
