| | | Forums66 Topics128,186 Posts1,057,303 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 182 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 182 | Were gas tank filler tubes painted on the old Chevy pick-ups - specifically the Art Deco pick-ups? If so, were they black or body color? | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | My son's 1946 2 ton filler neck painted Brewster Green the same as the truck body.
| | | | | Joined: Mar 2010 Posts: 10,309 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,309 | How many horses pulled that there 2 ton 1846 carriage? (Just yanking your chain there buddy.)
| | | | | Joined: Aug 2010 Posts: 182 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 182 | Is the filler neck painted even on the inside of the cab? | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | How many horses pulled that there 2 ton 1846 carriage? (Just yanking your chain there buddy.) Depends on the size of the horse.  | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | Is the filler neck painted even on the inside of the cab? The first answer was free. What do you got to give? My son has the truck out on the North Fork right now so I can not measure and say exactly how far down the paint goes on the filler neck. Though it definitely goes past the filler neck grommet so no bare metal is seen on the outside of the cab. Though the paint did not go all the way to the tank if I remember right. The truck may be coming home today.
| | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Mine was body color to the cab and raw metal on the inside with a hint of overspray. Dan | | | | | Joined: Oct 2012 Posts: 182 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 182 | Mine was body color to the cab and raw metal on the inside with a hint of overspray. Dan Same with my 1941 trucks (original paint). | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Mine was body color to the cab and raw metal on the inside with a hint of overspray. Dan Exterior color overspray or interior color? | | | | | Joined: Aug 2010 Posts: 182 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 182 | Looks like the filler necks were painted ahead of time at the factory to match the cab, eh? | | | | | Joined: Aug 2010 Posts: 182 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 182 | The next question then is: was the filler neck seal retaining ring also painted to match the cab, or was it painted black on the '42-46 models that had that type of seal? | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | It was painted body color. Harold
Harold Is a restoration ever finished? | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Not Art Deco , but my advanced design also had remnants of exterior color inside.
| | | | | Joined: Aug 2010 Posts: 182 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 182 | Thanks. I really appreciate all the input! | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | 1946 2 ton tank filler neck was painted 3" into the cab.
The ring that holds grommet on the filler neck painted the same as the body. | | |
