1 members (Phak1), 65 guests, and 1 robot.
Topics128,022
Posts1,055,361
Members48,420
#111110 08/06/2002 3:52 PM
The other day at a local truck show I seen a
nice GMC 1/2 ton....the dash was a very dark gray with a low luster shine..I know this is not origianl...but it was nice..Can I go to the
local paint store and get this in a spray can...sorry about the novice question...
1946 chevy 1/2 ton panel
1937 ford coupe
#111111 08/06/2002 7:27 PM
most likely not if you try to do that it will probly fade and peal off
DUSTY G.
you can do anything you want as long as you have an O [censored] man in case you mess up
#111112 08/06/2002 11:58 PM
You can get any paint color or type in a spray can. Most paint dealers can put any paint into a spray can. Out here it's about $20.00 (Canadian) per can. If I were you I'd lightly sand (1000 grit) - prime and paint it ... It may peel but the odds are against it ...
#111113 08/07/2002 1:21 AM
They sell fillable spray cans. You fill them yourself. Under $10
54 3100 with 235
62 flatbed dump C60 with 261
#111114 08/07/2002 1:27 AM
its all in the prep work but the reason you use a gun is for better control over the paint and air flow.
and if your going to prime it use 320 than clean it with a paint prep. prime than wet sand 600 than clean it again than spray. do lite coats with 10min intervals
DUSTY G.
#111115 08/07/2002 1:34 AM
k10 Offline
Don't be too sure about it not being factory correct. If it's a 60-66, it's right.
#111116 08/10/2002 6:37 AM
Flat dark gray was also used on 57-59 to reduce glare off of the dash. Jim Carter carries the paint.
