2 members (2-Ton, mick53),
75
Mod | | | Forums66 Topics128,030 Posts1,055,419 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2000 Posts: 112 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 112 | The other day at a local truck show I seen a nice GMC 1/2 ton....the dash was a very dark gray with a low luster shine..I know this is not origianl...but it was nice..Can I go to the local paint store and get this in a spray can...sorry about the novice question...
1946 chevy 1/2 ton panel 1937 ford coupe | | | | | Joined: Jul 2002 Posts: 46 Member | | Member Joined: Jul 2002 Posts: 46 | most likely not if you try to do that it will probly fade and peal off
DUSTY G.
you can do anything you want as long as you have an O [censored] man in case you mess up
| | | | | Joined: Feb 2000 Posts: 203 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 203 | You can get any paint color or type in a spray can. Most paint dealers can put any paint into a spray can. Out here it's about $20.00 (Canadian) per can. If I were you I'd lightly sand (1000 grit) - prime and paint it ... It may peel but the odds are against it ... | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | They sell fillable spray cans. You fill them yourself. Under $10
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Jul 2002 Posts: 46 Member | | Member Joined: Jul 2002 Posts: 46 | its all in the prep work but the reason you use a gun is for better control over the paint and air flow.
and if your going to prime it use 320 than clean it with a paint prep. prime than wet sand 600 than clean it again than spray. do lite coats with 10min intervals
DUSTY G.
| | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | Don't be too sure about it not being factory correct. If it's a 60-66, it's right. | | | | | Joined: Feb 2001 Posts: 41 Member | | Member Joined: Feb 2001 Posts: 41 | Flat dark gray was also used on 57-59 to reduce glare off of the dash. Jim Carter carries the paint. | | |
