0 members (), 172 guests, and 2 robots.
Topics128,101
Posts1,056,182
Members48,436
I'm in the process of swapping the 235 out of my '59 Apache and putting in a 283. I intend on keeping the direct oil pressure reading to the guage. I noticed tonight that where the oil pressure switch on the 283 goes, the opening is larger than the opening on the 235. What did any of you guys that put V8's in do to keep the direct pressure reading? I'm not wanting to add a dash mounted electric oil pressure guage.
1959 3100 Apache Fleetside
get a pipe fitting to adapt the line
That is what I did on mine.
don
The 283 has a 1/8" pipe thread beside the distributor for oil pressure. There is an adapter available to go from the pipe thread to a compression fitting on the oil pressure line, which is usually a 1/8" or 3/16" OD copper tube. Most well-equipped parts stores will have an assortment of brass compression fittings, but don't ask the mouth-breather computer jockey at the counter to help you find the right fitting. Look for the gray bearded oldtimer who knows how to read a paper catalog and has more than three brain cells to rub together!
Here's a pic:
http://thumbs1.ebaystatic.com/d/l225/m/mzt9noGWhLIpvHypH0gas4g.jpg
Good luck!
Thanks for the inputs. I'm going to a local hose shop and see if they have what I need. I bought 8 of the compression fittings from O'Reilly's (6 for spares in case I screw one up) quite cheap, less than a buck each.
