1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#1110924 06/30/2015 6:50 AM
I disassembled my engine for rebuilding and removed the oil pump mount from the block,some people say the block is now no good,since it was factory aligned.but I also talked to a local rebuild shop that also removed this adapter while rebuilding a 261, it's been running since 2003, your thoughts?
1962 GMC 920 step side 261 4 spd
I have not worked much on these engines. Though I can not visualize how you would of harmed your engine. Though I an sure those in the know will respond.
As long as you use the original shouldered bolts you will be okay.
I would put the oil pump and distributor in place while tightening the shouldered bolts to make sure everything is lined up.
I have needed to do this in the past and it is still working fine.
To reuse the original bolts grind six sides in the head to except a socket.
My Blog
H Online: Content
It's also possible to drill a hole in the bolt head and use a cutoff Allen wrench and a BFH to form a six-sided socket. Use a Vise Grip to hold the Allen wrench and form the hex with one hard blow. A 1/4" drill bit and the same size hex wrench should work about right. I'd suggest machining a close-fitting alignment shaft that fits the block and the oil pump mount to keep it in place while re-bolting it.
Thanks guys ,spent some time worrying about this,I did think about each of those ideas, machining a shaft to fit , and also assembling the distributor,oil pump and adapter,but also installing the cam and giving it a spin to align things up.the block is in the machine shop getting a sleeve,due to catastrophic piston failure.this is my first old engine I've been in to,I am a HD diesel mechanic and I thought this would be easy. There will be no rushing this repair.
