| | | Forums66 Topics128,126 Posts1,056,353 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2014 Posts: 152 'Bolter | | 'Bolter Joined: Jun 2014 Posts: 152 | hi guys
did the 49 1/2 ton come with a footstarter as stock?
is it possible to convert a 12v neg ground electrical operated 56 starter to a footstart starter by changing just the solenoid?
anyone have the bits i need?
cheers mike
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Yes a 1949 would be foot start. It is not possible to convert a solenoid starter to foot start, but a 1955-59 truck 12 volt starter is already set up for foot start. I am assuming you already have a 12 volt starter?
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | A 12V starter needs a 12V flywheel. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | mike,
Do you want 6v or 12v system with an electrical-solenoid starter?
What year/size engine.
| | | | | Joined: Jun 2014 Posts: 152 'Bolter | | 'Bolter Joined: Jun 2014 Posts: 152 | hi guys, truck is 49 but engine is a 56 12v 235 so not sure what i need lol my starer looks like this one starter i guess i need one like this? foot starter or could i just convert my starter using this starter switch and fix a foot stomp mechanism to the gear engaging bracket , would safe on shipping costs
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The one you have has a black tag, that makes it a 6 volt starter. The one you linked to from Carter is for a V8, or maybe 235 with hydromatic? As mentioned above you need to know which flywheel you have.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2014 Posts: 152 'Bolter | | 'Bolter Joined: Jun 2014 Posts: 152 | hi dave
thanks,
yes my starter has a black tag, truck is 12v though so not sure whats happening there. i read that a lot of people run 6v starters at 12v without issues
hmm what should i look for to ID the flyweel?
ill take some pics of the id plate and starter tonight
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Did the starter you have come with the flywheel? 6 volt starters work fine on 12 volts. If your not sure which flywheel you have you can count the teeth on it.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | 139 teeth = 6V 168 teeth = 12V | | | | | Joined: Jun 2014 Posts: 152 'Bolter | | 'Bolter Joined: Jun 2014 Posts: 152 | thanks guys
i counted 4 teeth/inch so im assuming its a 6v flywheel the starter i have (that came with it) is according to the number on the id plate a 6v from a 49-51 chevy car or COE (number 1107075) so i guess a stock 6v starter 1107055 is what i need to convert to foot start.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 1938-48 passenger, or 1938-54 truck starter is what you are looking for. Here is an example on eBay.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2014 Posts: 152 'Bolter | | 'Bolter Joined: Jun 2014 Posts: 152 | thanks dave et al, ive abused my paypal on ebay and got together a starter and starter assembly so should be good to go thanks all for the advice | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | This may help: no matter what year engine, 216,235 261; keep everything from bell housing back together, the 49 bellhousing, flywheel, starter(works great with 12v), foot linkage, do not combine with any of the late motor's trany/clutch parts. ie, my 46 pickup, has 46 bellhousing, flywheel clutch, starter etc but the entire engine is a 1961 261, been great for 30 years. | | |
