| | | Forums66 Topics128,026 Posts1,055,399 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 16 Junior Member | | Junior Member Joined: Sep 2003 Posts: 16 | Hey Guys, How much trouble is it to make 51 doors one piece glass | | | | | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | darn near impossible.
The window mechanism, upper door frame, internal braces, inner and outer doorskins will all have to be removed and completely refabricated to allow this to happen. Then you will need to find a set of earlier inner window frames to cover the hacker scars. You will have an easier time of it if you pick up a pair of early AD (47-50) doors that never had wingvents and shave the doorhandles. | | | | | Joined: Sep 2003 Posts: 16 Junior Member | | Junior Member Joined: Sep 2003 Posts: 16 | Thanks; Hedgehog, Sounds like you may have done one?!!!! | | | | | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | Nope, I love my wing windows and use them all the time for ventilation. However, when I got the truck they were rusted solid and leaked around the clouded/broken glass. I looked into the same idea and decided it was cheaper and more utilitarian to buy a set of vent frames from a boneyard and build new wing assemblies. | | |
