1 members (1 invisible), 105 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#111073 10/31/2003 10:56 PM
Junior Member
Junior Member
Hey Guys, How much trouble is it to make 51 doors one piece glass
#111074 11/01/2003 3:31 AM
darn near impossible.
The window mechanism, upper door frame, internal braces, inner and outer doorskins will all have to be removed and completely refabricated to allow this to happen. Then you will need to find a set of earlier inner window frames to cover the hacker scars. You will have an easier time of it if you pick up a pair of early AD (47-50) doors that never had wingvents and shave the doorhandles.
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
#111075 11/04/2003 1:53 PM
Junior Member
Junior Member
Thanks; Hedgehog, Sounds like you may have done one?!!!!
#111076 11/05/2003 12:58 AM
Nope, I love my wing windows and use them all the time for ventilation. However, when I got the truck they were rusted solid and leaked around the clouded/broken glass. I looked into the same idea and decided it was cheaper and more utilitarian to buy a set of vent frames from a boneyard and build new wing assemblies.
