8 members (Otto Skorzeny, 68ironhead, 3B, Jon G, Gdads51, NJC, 2 invisible), 104 guests, and 1 robot.
Topics128,130
Posts1,056,369
Members48,441
hi guys
did the 49 1/2 ton come with a footstarter as stock?
is it possible to convert a 12v neg ground electrical operated 56 starter to a footstart starter by changing just the solenoid?
anyone have the bits i need?
cheers
mike
Yes a 1949 would be foot start.
It is not possible to convert a solenoid starter to foot start, but a 1955-59 truck 12 volt starter is already set up for foot start.
I am assuming you already have a 12 volt starter?
My Blog
A 12V starter needs a 12V flywheel.
mike,
Do you want 6v or 12v system with an electrical-solenoid starter?
What year/size engine.
hi guys,
truck is 49 but engine is a 56 12v 235
so not sure what i need lol
my starer looks like this one
starter
i guess i need one like this?
foot starter
or could i just convert my starter using this
starter switch
and fix a foot stomp mechanism to the gear engaging bracket
, would safe on shipping costs
The one you have has a black tag, that makes it a 6 volt starter.
The one you linked to from Carter is for a V8, or maybe 235 with hydromatic?
As mentioned above you need to know which flywheel you have.
My Blog
hi dave
thanks,
yes my starter has a black tag, truck is 12v though so not sure whats happening there. i read that a lot of people run 6v starters at 12v without issues
hmm what should i look for to ID the flyweel?
ill take some pics of the id plate and starter tonight
It could be a 6v car starter or a 6v step van starter?
It is not a 54/55 Hydra-Matic starter - H-M starter on top and regular truck starter on bottom
Here is a thread that discusses 6v starters.
Did the starter you have come with the flywheel?
6 volt starters work fine on 12 volts.
If your not sure which flywheel you have you can count the teeth on it.
My Blog
139 teeth = 6V
168 teeth = 12V
thanks guys
i counted 4 teeth/inch so im assuming its a 6v flywheel
the starter i have (that came with it) is according to the number on the id plate a 6v from a 49-51 chevy car or COE (number 1107075) so i guess a stock 6v starter 1107055 is what i need to convert to foot start.
1938-48 passenger, or 1938-54 truck starter is what you are looking for. Here is an example on eBay.
My Blog
thanks dave et al,
ive abused my paypal on ebay and got together a starter and starter assembly so should be good to go
thanks all for the advice
This may help: no matter what year engine, 216,235 261; keep everything from bell housing back together, the 49 bellhousing, flywheel, starter(works great with 12v), foot linkage, do not combine with any of the late motor's trany/clutch parts. ie, my 46 pickup, has 46 bellhousing, flywheel clutch, starter etc but the entire engine is a 1961 261, been great for 30 years.
1946 1/2-Ton Chevy
