4 members (Steelonsteel, Rich'sToys, Brian Moore, klhansen), 81 guests, and 2 robots.
Topics128,037
Posts1,055,465
Members48,422
#1109761 06/23/2015 10:28 PM
when replacing clutch disc which way do the springs go, toward the flywheel or toward the pressure plate? 46 1/2 ton
hoozat #1109778 06/24/2015 12:05 AM
U
U Offline
Look very closely at the clutch disc; most say "toward flywheel" or "flywheel side".
Brad
Wrench Fetcher, PhD
hoozat #1109795 06/24/2015 1:58 AM
Denny G
Sandwich, IL
hoozat #1109994 06/25/2015 12:01 AM
i need to know if I put my disc in wrong
hoozat #1110039 06/25/2015 2:47 AM
The springs go away from the flywheel. If they are installed towards the flywheel they will rub against the flywheel bolts. (I know this because the previous owner of my replacement engine installed the disk backwards. LOL.)
hoozat #1110121 06/25/2015 4:02 PM
Did you look at the illustration that was posted????
The long part of the hub towards the front is another clue.
dg
Denny G
Sandwich, IL
hoozat #1110148 06/25/2015 7:38 PM
ok, I got it in right, but when I let the clutch out it makes a noise like something is hitting in there, I cant find any marks where it would hit....maybe if I backoff on the clutch adjustment??
Maybe shim out the starter? trying all options at this point
