8 members (JW51, Woodcmiami, Gdads51, dt235sd, MickeyP, HandyAndy, k2handyman, 1 invisible),
58
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,699 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 15 New Guy | | New Guy Joined: Dec 2001 Posts: 15 | Local shop wants $30 to blast my tailgate. Is that a good price or a rip-off? | | | | | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | You could always do what I did. Spend a thousand bucks on a nice blast cabinet, then another thousand on a 5 Hp 2 Stage air compressor, then another couple hundred for a dryer and a regulator.. Throw in another hundred or so for pipe and fittings.. When you fire up that compressor , watch your electric meter spin off the side of the house..Now you are in the blasting business..
30 bucks is a good deal, grab it.
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | Rugo just had his frame media blasted . . . not sure what he paid. Rugo??? | | | | | Joined: Mar 2001 Posts: 265 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 265 | The answer to Ken's question about how much I spent to have my rolling chassis media blasted, is $170. However that included three of the bed crossmembers, two small and the big rear one that runs under the tailgate. I chose media for the reason that it is not going to be as abrasive in moving parts, leaf springs, brakes etc, if I didn't get every last granual when cleaning it up. Sand can cause alot more problems. I do plan to clean very thoroughly, but you never know. It didn't cost anymore in this case. So why not? I hope this helps in your decision whether to have you tailgate done for $30.
Rugo 53 3100 Smokem if you gottem, if you haven't gottem, I know where you can gettem.
Steve Rugg 53 3100
| | | | | Joined: Dec 2001 Posts: 15 New Guy | | New Guy Joined: Dec 2001 Posts: 15 | I appreciate ya'lls input. After seeing how Bill put it, maybe $30 is a pretty good deal after all. Thanks. Curt | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Round here blast sand is $7.50 a bag. Figure at least one bag for a tailgate. Add in the blaster, hood, respirator and other necessaries, and you'll need to go into business to pay for it all! I blasted two wheels for my truck, took 4 bags and I used the equipment at our museum. That includes a 3 phase compressor, which ran all the time when I blasted. When I get newer wheels for the front, I will pay for someone to blast them.
Fred 52 3600 69 C-10
| | | | | Joined: Jan 2001 Posts: 198 Member | | Member Joined: Jan 2001 Posts: 198 | The only other way is to rent and undustrial air compressor and media tank, but still runs around $200 a day for the diesel compressor and the sand blaster tank, and you still have the media to buy and the fuel, But if your are going to do a complete chassis it might be a cheaper way to go or if you have a friend in the construction business they might know where you can get a loan of the jack hammer type tag along compressor, as they work really good for air volume and cheap to run, 200cfm@ 110 psi and uses around 3L of fuel per hour, cheaper than hydro. | | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | i sweep up my sand and pour it through a flour sifter and reuse it. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I'm thinking about converting my extra stovebolt engines into an air compressor, one driving, one compressing, on a trailer. Anyone want one? That should give enough cfm for blasting. Now I gotta find two radiators, a governor, and a trailer to mount them on.
