1 members (klhansen), 107 guests, and 1 robot.
Topics128,062
Posts1,055,856
Members48,428
#110989 10/11/2002 3:05 AM
Local shop wants $30 to blast my tailgate. Is that a good price or a rip-off?
#110990 10/11/2002 3:35 AM
You could always do what I did. Spend a thousand bucks on a nice blast cabinet, then another thousand on a 5 Hp 2 Stage air compressor, then another couple hundred for a dryer and a regulator.. Throw in another hundred or so for pipe and fittings.. When you fire up that compressor , watch your electric meter spin off the side of the house..Now you are in the blasting business..
30 bucks is a good deal, grab it.
Bill M
53 GMC Hydra-Matic
Home Page
http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#110991 10/11/2002 4:49 AM
Anonymous
Unregistered
Anonymous
Unregistered
Rugo just had his frame media blasted . . . not sure what he paid. Rugo???
#110992 10/11/2002 9:04 PM
The answer to Ken's question about how much I spent to have my rolling chassis media blasted, is $170. However that included three of the bed crossmembers, two small and the big rear one that runs under the tailgate. I chose media for the reason that it is not going to be as abrasive in moving parts, leaf springs, brakes etc, if I didn't get every last granual when cleaning it up. Sand can cause alot more problems. I do plan to clean very thoroughly, but you never know. It didn't cost anymore in this case. So why not? I hope this helps in your decision whether to have you tailgate done for $30.
Rugo
53 3100
Smokem if you gottem, if you haven't gottem, I know where you can gettem.
Steve Rugg
53 3100
#110993 10/12/2002 2:50 AM
I appreciate ya'lls input. After seeing how Bill put it, maybe $30 is a pretty good deal after all. Thanks.
Curt
#110994 10/12/2002 4:44 AM
Round here blast sand is $7.50 a bag. Figure at least one bag for a tailgate. Add in the blaster, hood, respirator and other necessaries, and you'll need to go into business to pay for it all! I blasted two wheels for my truck, took 4 bags and I used the equipment at our museum. That includes a 3 phase compressor, which ran all the time when I blasted. When I get newer wheels for the front, I will pay for someone to blast them.
Fred
52 3600
69 C-10
#110995 10/12/2002 1:39 PM
The only other way is to rent and undustrial air compressor and media tank, but still runs around $200 a day for the diesel compressor and the sand blaster tank, and you still have the media to buy and the fuel, But if your are going to do a complete chassis it might be a cheaper way to go or if you have a friend in the construction business they might know where you can get a loan of the jack hammer type tag along compressor, as they work really good for air volume and cheap to run, 200cfm@ 110 psi and uses around 3L of fuel per hour, cheaper than hydro.
#110996 10/13/2002 2:00 AM
Z
Z Offline
i sweep up my sand and pour it through a flour sifter and reuse it.
#110997 10/14/2002 11:22 PM
I'm thinking about converting my extra stovebolt engines into an air compressor, one driving, one compressing, on a trailer. Anyone want one? smile
That should give enough cfm for blasting. Now I gotta find two radiators, a governor, and a trailer to mount them on.
Paint & Body Shop moderator
