2 members (Southerntruck, Gdads51), 130 guests, and 2 robots.
Topics128,128
Posts1,056,668
Members48,450
#1109206 06/20/2015 5:03 PM
What is the best way to lower the rear without causing a harsher ride? I put in lowering blocks and it seem the ride is much stiffer, any suggestions?
You might find some help with these folks or just looking at there tech help will give a bit more understanding of things.
https://www.eatondetroitspring.com/wp-content/uploads/st101.pdf
Baking in the nice desert sun, breathing life back into a 48 3800 5 window.
I had my springs rebuilt, lowering blocks and installed tube shocks all the way around. Also radial tires, front sway bar, every little bit helps.
1946 1/2-Ton Chevy
Thanks, great site to start with.
Thanks, I put on adjustable shocks on rear, But rebuilding the springs might be the answer, maybe removing a leaf or two, or reversing the eye bushings. Nice truck and great story, something alluring about these art deco beauty queens always makes me smile.
take a couple of leaves out of the springs...it will soften up the ride for you with the lowering blocks......did it on my 46 and it rides fine
